9 years, 9 months ago.
Teensy 3.2 and mbed-rtos
I am trying to get mbed-rtos working on my Teensy 3.2.
I am using the following code:
#include "rtos.h"
DigitalOut led(D13);
void blink(void const *args)
led = !led;
int main(void)
RtosTimer led_timer(blink, osTimerPeriodic, (void *)0);
led_timer.start(1000);
Thread::wait(osWaitForever);
And I am getting the following errors:
Quote:
Warning: Incompatible redefinition of macro "MBED_CMSIS_RTOS_CM" in "mbed-rtos/rtx/TARGET_CORTEX_M/cmsis_os.h", Line: 60, Col: 10
Warning: Incompatible redefinition of macro "CMSIS_RTOS" in "mbed-rtos/rtx/TARGET_CORTEX_M/cmsis_os.h", Line: 62, Col: 10
Warning: Intrinsic is deprecated in "mbed-rtos/rtx/TARGET_CORTEX_M/rt_HAL_CM.h", Line: 209, Col: 17
Warning: Intrinsic is deprecated in "mbed-rtos/rtx/TARGET_CORTEX_M/rt_HAL_CM.h", Line: 212, Col: 13
Warning: Intrinsic is deprecated in "mbed-rtos/rtx/TARGET_CORTEX_M/rt_HAL_CM.h", Line: 214, Col: 18
Warning: Intrinsic is deprecated in "mbed-rtos/rtx/TARGET_CORTEX_M/rt_HAL_CM.h", Line: 216, Col: 13
Error: A1854E: Unknown opcode 'VSTMDBEQ', maybe wrong target CPU? in "mbed-rtos/rtx/TARGET_CORTEX_M/TARGET_RTOS_M4_M7/TOOLCHAIN_ARM/HAL_CM4.c", Line: 167, Col: 1
Error: A1854E: Unknown opcode 'VLDMIANE', maybe wrong target CPU? in "mbed-rtos/rtx/TARGET_CORTEX_M/TARGET_RTOS_M4_M7/TOOLCHAIN_ARM/HAL_CM4.c", Line: 187, Col: 1
Error: A1854E: Unknown opcode 'VSTMDBEQ', maybe wrong target CPU? in "mbed-rtos/rtx/TARGET_CORTEX_M/TARGET_RTOS_M4_M7/TOOLCHAIN_ARM/HAL_CM4.c", Line: 250, Col: 1
Error: A1854E: Unknown opcode 'VLDMIANE', maybe wrong target CPU? in "mbed-rtos/rtx/TARGET_CORTEX_M/TARGET_RTOS_M4_M7/TOOLCHAIN_ARM/HAL_CM4.c", Line: 269, Col: 1
I am not sure what to do to fix this?
9 years, 8 months ago.
Hi, thanks for reporting, I created a tracking issue, the fix is included, will require testing and then should be part of the release in 2 weeks.
https://github.com/mbedmicro/mbed/issues/2118
Have you found the answer yet? I am stuck at the same thing
posted by Edge Botix 06 Jul 2016
