9 years, 10 months ago.
Simple DigitalOut blink only between 0V and 2V Pin initialisation error?
This very simple program blinks PA_5, however when looking at the traces on an oscilloscope, the HIGH voltage is only 2V, however, when removing the line declaring PB_7 as digitalOut, it blinks at full 3V3. I believe there is a problem with the pin initialisation in the mbed library for the F303K8, I would be grateful for any help to identify / fix this error.
Test Code
DigitalOut myled(PA_5);
DigitalOut M2b(PB_7); //enabling / disabling this changes the voltage range of PA_5
myled = 1; // LED is ON
wait(0.2); // 200 ms
myled = 0; // LED is OFF
wait(0.5); // 1 sec
PA_5 waveform, when DigitalOut M2b(PB_7); is included
PA_5 waveform, when DigitalOut M2b(PB_7); is NOT included
9 years, 8 months ago.
Check User Manual, Solder bridges SB16 and SB18 link PA_6 and PA_5 to PB_6 and PB_7 respectively. Something to do with i2c compatibility with Arduino Uno. SB16 and SB18 need to be removed to 'float' PA_5 and PA_6.
I'm unfamiliar with your hardware. What circuitry is the pin using PB_7 connected to - could it be affecting the voltage seen on the pin PA_5?
In my experience, when an output doesn't reach its expected "high" voltage, that output is often connected to another output.
posted by Mike G 29 May 2016
