9 years, 9 months ago.
mDot Box Factory Firmware not sending survey data
I think there is a Survey mode bug in the current Box Factory Image (both binary and git repo) causing survey data to never get sent.
I am not seeing survey data being sent (only link check requests) when running either the released binary or a build of the git code. I found in the code that survey data is only sent if _send_data flag is nonzero. The _send_data flag is initialized to the value of mDot->getStartUpMode(), which by default is COMMAND(0).
In survey start() I added code to set startup mode to SERIAL(1) and as a result survey packets are now being sent.
Here is running fw build info: ATI MultiTech mDot Firmware: 2.0.0-mbed Library : 0.0.9-1-ge7286ba
