9 years, 11 months ago.
Converting float value to char *array
Hello, I have a pointer array. I am trying to convert float value into char so I can store it in the array. How it is possible? I am using a way but it is not working. The compiler is building it but it is not working in real system.
This is my array -> char *zone_value[]={"0.00","0.00","0.00","0.00"," "};
float value is -> float value=0.25;
sprintf(zone_value[zone],"%f",value );
Any suggestions?
I'm using this for converting a single float (value) to a char array:
uint8_t *floatArray = (uint8_t *) &value; /* ftoa */
sstaub
Your original code could easily corrupt the storage space...
// zone_value is an array of pointers.
// zone_value[0] points to a string with only 5 storage locations: '0', '.', '0', '0', '\0'
char *zone_value[]={"1.23","4.56","7.89","0.00"," "};
// In memory as \x31, \x2E, \x32, \x33, \x00, \x34, \x2E, \x35, \x36, ...
// The following sprintf could easily overrun the storage as the value
// might expand to a string greater than the original storage.
sprintf(zone_value[zone], "%f", value); // if value was 1.234 it would overrun the storage
// becomes \x31, \x2E, \x32, \x33, \x34, \x00, \x2E,
As an alternate, you might pre-allocate storage for the strings, and you will want to specify the formatter to control the expansion
#define MAX_LEN_FLT 10
#define NUM_ZONES 5
char * zone_value[NUM_ZONES][MAX_LEN_FLT];
// use the secure form of printf to avoid buffer overrun errors
// and reserve space for the sign, in case value could be < 0
int r = snprintf(zone_value[zone], MAX_LEN_FLT, "%+5.3f", value); // "-12.345"
// always a good idea to check the return code
if (r < 1 || r > MAX_LEN_FLT)
printf("unable to convert value to a float\n");
Is there a good reference somewhere for the "safe" forms of these commands. I don't think the textbooks I have even mention them.
posted by 25 Apr 2016Hi Oliver,
That's a great question - which might deserve its own thread of discussion. I hope others can help answer. Some libraries append _s to the functions to indicate the secure version, but this is not the "standardized" form I guess. I think C++ string functions are probably more secure (e.g. string a; a += "hello";) but for some applications I avoid these as they can cause severe memory fragmentation. I tried searching for "secure c string functions" and there are a lot of hits.
Generally, anything that writes to a buffer, should also pass the size of the buffer, so the function can avoid overrun. "strcpy" gets replaced with "strncpy" for instance.
posted by 25 Apr 20169 years, 11 months ago.
Don't know what your application is, if you want to fill a dynamic float value array, I would do this, mainly as I use something similar. But this may be a homework question.
snip-tested
float zone_value[101];
zone_value[0] = 0.00;
zone_value[1] = 1.65;
zone_value[2] = 0.00;
zone_value[3] = 4.21;
zone_value[4] = 3.68;
zone_value[99] = 6.37;
for(int n = 0; n < 5; n++) {
sprintf(buffer,"zone value %d: = %1.2f \n",n,zone_value[n]);
sprintf(buffer,"zone value 99: = %1.2f \n",zone_value[99]);
