10 years ago.
Unknown Shift of AnalogOut Pins
I'm a novice at mbed. When I use mbed to build program for my Nucleo F303K8 board, I found the AnalogOut Pins will shift! There are three DAC channels on this board: PA_4 (A3), PA_5 (A4), and PA_6 (A5). For example, when I define: AnalogOut aop1(PA_4); and execute: aop1=1; It's ok. And the voltage on PA_4 is exactly 3.3V.
Or, if I define: AnalogOut aop1(PA_4); AnalogOut aop2(PA_5); and execute: aop1=1; It also works well.
BUT, if I define both PA_4 and PA_6 together, like: AnalogOut aop1(PA_4); AnalogOut aop3(PA_6); and execute: aop1=1; I CAN'T get any voltage on PA_4 pin, WHILE the voltage on PA_6 will be 3.3V!
Furthermore, when I use all of three pins, like: AnalogOut aop1(PA_4); AnalogOut aop2(PA_5); AnalogOut aop3(PA_6); and execute: aop1=1; aop2=1; aop3=1; Only PA_6 has a 3.3V voltage. For both PA_4 and PA_5, the voltage is ZERO.
When the command 'AnalogOut' is replaced by 'DigitalOut', it runs smoothly.
I'm quite puzzled about what happen. Hope someone could address my question.
Affordable and flexible platform to ease prototyping using a STM32F303K8T6 microcontroller.
9 years, 9 months ago.
I have the same issues. Looking forward to a solution for this problem!
Check User Manual, Solder bridges SB16 and SB18 link PA_6 and PA_5 to PB_6 and PB_7 respectively. Something to do with i2c compatibility with Arduino Uno. SB16 and SB18 need to be removed to 'float' PA_5 and PA_6.
