10 years, 12 months ago.
Kinetis Interface Tool V2 KIT 2 Rev. 2.1. Problem With Example Command Interface File(s)
Hello, I get errors when I test the command interface in the Kinetis Interface Tool Using the sample command list files. The problem only occurs with '0x01 0x02 0x02 0x00 0x01 0x52 // Start APP Streaming' commands listed in the files. Are these 'Sub<n>_Data.txt' files the correct command files for testing? Is this the correct byte-code command for the 'Start APP Streaming' command for this version of 'FRDM-STBC-AGM01' on 'FRDM-K64F' (FRDM-K64F-AGM01)? The details are listed below. Thanks. Path: CommandListFiles/ Files: Sub1_Data.txt Sub2_Data.txt Sub3_Data.txt Sub4_Data.txt Sub5_Data.txt The following are sample returned text from using 'Sub1_Data.txt' as input: Device connected at COM5 Writing To Device- 01 01 06 00 00 Protocol: ISF Command Interpreter - Device Response 01 01 80 00 00 Writing To Device- 01 02 06 00 00 Protocol: ISF Command Interpreter - Device Response 01 02 80 00 00 Writing To Device- 01 01 02 2C 0C 02 0A 02 0B 02 0C 02 0D 02 0E 02 0F Protocol: ISF Command Interpreter - Device Response 01 01 80 0C 0C Writing To Device- 01 01 02 18 14 02 00 02 01 02 02 02 03 02 04 02 05 02 06 02 07 02 08 02 09 Protocol: ISF Command Interpreter - Device Response 01 01 80 14 14 Writing To Device- 01 01 02 38 01 04 Protocol: ISF Command Interpreter - Device Response 01 01 80 01 01 Writing To Device- 01 02 02 00 01 52 Protocol: ISF Command Interpreter - Device Response Error! The text of 'Sub1_Data.txt' is as follows: 0x01 0x01 0x06 0x00 0x00 // Reset MBOX 0x01 0x02 0x06 0x00 0x00 // Reset APP 0x01 0x01 0x02 0x2C 0x0C 0x02 0x0A 0x02 0x0B 0x02 0x0C 0x02 0x0D 0x02 0x0E 0x02 0x0F // TS + ACCEL #1 0x01 0x01 0x02 0x18 0x14 0x02 0x00 0x02 0x01 0x02 0x02 0x02 0x03 0x02 0x04 0x02 0x05 0x02 0x06 0x02 0x07 0x02 0x08 0x02 0x09 // TS + ACCEL #2 0x01 0x01 0x02 0x38 0x01 0x04 // Enable CI Streaming 0x01 0x02 0x02 0x00 0x01 0x52 // Start APP Streaming 0x01 0x02 0x02 0x00 0x01 0x50 // Stop APP Streaming
10 years, 8 months ago.
Hello Peter,
I get exactly the same error message with a K64 board. When using a KL25, the interface works properly. I believe there is a bug at the firmware for the K64 board.
I have just reported that to the adequate forum at the Freescale Community, where probably the creators of the toolbox may answer that. I suggest you to follow it:
https://community.freescale.com/message/532315#532315
Cheers,
Antonio
This has been resolved. I simply downloaded Sensor Fusion Toolbox and used that instead.
Here is the link to the download for windows: https://community.freescale.com/docs/DOC-104000
P
posted by Peter Willis 28 Mar 2015
