11 years, 1 month ago.
How do save an audio file on LPC1768
Are there any tutorials on how to create and save a short audio file onto an LPC 1768 to be played when it receives an input?
I use .wav files , a SD card , the DAC of the LPC1768 and a earphone. I shall add amplifier for a little speaker
The wav files are recorded with Audacity and resampled to 16 bits, mono 16kHz.
Another solution is http://www2.research.att.com/~ttsweb/tts/demo.php
The sound files are stored on a SD card, because the LocalFileSystem is too slow and inhibits the interrupts.
If you want to store the files in the flash memory...look at IAPhttp://developer.mbed.org/cookbook/Homepage
The wav file player I use is here :http://developer.mbed.org/users/sravet/code/wave_player/
I tested a LM386 as amplifier , this was too noisy on my pcb. I am lloking at a TDA7052A.
I hope this can help you.
When you say audio files, do you mean mp3?
posted by Paul Staron 20 Feb 2015Hi Paul. Any kind the simpler the better the file I have recorded is 172KB
posted by John O Loughlin 20 Feb 2015
