10 years, 3 months ago.
Makefile: GCC offline compiling and copying to MBED
I use GCC compiler under Linux. Does any one know, how to modify Makefile, to copy the .bin to the target MBED right after compile?
I have this line inserted in Makefile, there are no errors, the compilyng works OK, but the copy instruction never fires:
prog: cp $(PROJECT).bin /home/media/MBED1/$(PROJECT).bin sync #flush all buffers
I use MBED1, as far I have several MBEDs hooked to my computer.
Thank you for any answer.
Look at the syntax of a makefile, the full explanation is at www.gnu.org/software/make/manual/make.html
or a short one http://mrbook.org/blog/tutorials/make/
The basic makefile is composed of:
target: dependencies
[tab] system command
My makefile has one line with prog: and the next line begins with a tab
prog: cp $(PROJECT).bin /media/robert/MBED/$(PROJECT).bin sync #flush all buffers
Hi, I tried everything but with no result.
Here's my Makefile
<code>
.asm.o: $(CC) $(CPU) -c -x assembler-with-cpp -o $@ $< .s.o: $(CC) $(CPU) -c -x assembler-with-cpp -o $@ $< .S.o: $(CC) $(CPU) -c -x assembler-with-cpp -o $@ $<
.c.o: $(CC) $(CC_FLAGS) $(CC_SYMBOLS) -std=gnu99 $(INCLUDE_PATHS) -o $@ $<
.cpp.o: $(CPP) $(CC_FLAGS) $(CC_SYMBOLS) -std=gnu++98 -fno-rtti $(INCLUDE_PATHS) -o $@ $<
$(PROJECT).elf: $(OBJECTS) $(SYS_OBJECTS) $(LD) $(LD_FLAGS) -T$(LINKER_SCRIPT) $(LIBRARY_PATHS) -o $@ $^ $(LIBRARIES) $(LD_SYS_LIBS) $(LIBRARIES) $(LD_SYS_LIBS)
$(PROJECT).bin: $(PROJECT).elf $(OBJCOPY) -O binary $< $@
$(PROJECT).hex: $(PROJECT).elf @$(OBJCOPY) -O ihex $< $@
$(PROJECT).lst: $(PROJECT).elf @$(OBJDUMP) -Sdh $< > $@
lst: $(PROJECT).lst
size: $(PROJECT).elf $(SIZE) $(PROJECT).elf
prog: $(PROJECT).bin /media/gorazd/MBED1/$(PROJECT).bin sync #flush all buffers
DEPS = $(OBJECTS:.o=.d) $(SYS_OBJECTS:.o=.d) -include $(DEPS)
</code>
posted by 27 Nov 2015
