11 years, 1 month ago.
Remove Attach Function.
How can i Stop Attach Function Interrupt .?
Attach again with a null pointer as the function to call.
e.g. myTicker.attach(null,1);
Actually I don't think that works properly on Ticker (Andy's method), it does work for everything else though. But for Ticker use the detach function to stop it from being called.
Attaching zero works, it won't call your user function anymore, but the underlying hardware will keep generating the interrupt.
I might do a pull request to make it work like that, then it is more consistent :).
posted by 02 Feb 2015myTicker.stop(); and myInterrupt.fall(stop); would be more consistent with Timer T1.stop(); ???
