10 years, 6 months ago.
Asserted_held when released triggers deassert
Hi
I have set up a button "sw2" the following way on my FRDM-K64F board:
sw2.attach_deasserted( &sw2Frequency );
sw2.attach_asserted_held( &sw2TransceiveMode_held );
sw2.setSamplesTillAssert( 1 );
sw2.setSamplesTillHeld( 100 ); Held press for 20*100ms = 2 seconds
sw2.setAssertValue( 0 );
sw2.setSampleFrequency( 20000 );
What I want is:
- when sw2 is pushed and quickly released, sw2Frequency function is called.
- when sw2 is pushed and held for 2 seconds, sw2TransceiveMode_held function is called.
What I get is:
- when sw2 is pushed and quickly released, sw2Frequency function is called. (as I expect)
- when sw2 is pushed and held for 2 seconds, sw2TransceiveMode_held function is called. As I expect, EXCEPT when the button is released again, sw2Frequency function gets called.
How can I avoid calling sw2Frequency when releasing after a held press?
Thank you!
I found a solution!
EDIT: NOPE - still not working properly.
EDIT EDIT: Now it works as I want it to! Thanks to Andy A for helping me along the way.
See code below for my edit of the library (replace in PinDetect.h from line 459 till the end of the file).
void isr(void) {
        int currentState = _in->read();
        if ( currentState != _prevState ) { // only runs when change occur (switch)
            if ( _samplesTillAssert == 0 ) {
                _prevState = currentState;
                if ( currentState == _assertValue ){
                    _callbackAsserted.call();
                    _samplesTillHeld = _samplesTillHeldReload;
                if ( currentState != _assertValue && _samplesTillHeld ){
                    _callbackDeasserted.call();
                    _samplesTillHeld = 0;
                _samplesTillAssert = _samplesTillAssertReload;
            else {
                _samplesTillAssert--;
        if ( _samplesTillHeld ) {
            if ( _prevState == currentState ) {
                _samplesTillHeld--;
                if ( _samplesTillHeld == 0 ) {
                    if ( currentState == _assertValue ) {
                        _callbackAssertedHeld.call();
                    } else {
                        _callbackDeassertedHeld.call();
}; // namespace AjK ends.
using namespace AjK;
#endif
posted by Mathias Johnsen 21 Sep 2015
The library is doing exactly what you'd expect, when a button is released you get the callback for the button being released.
Two options to get what you want: 1: Change your code so that it ignores the first deasserted callback after an asserted held callback.
2: Change the library so that it does what you want..
Looking at the library if I'm understanding what it does correctly it's a case of adding one line and moving one other.
  void isr(void) {
                if (_samplesTillHeld)               // This if added.  - only call callback if button held count hasn't been reached.
                  else
                _samplesTillHeld = _samplesTillHeldReload;  // This line moved down
            else {
        else {
                _samplesTillHeld--;
                    else
            else {
Thank you for your helpful reply! Unfortunately, changing the library the way you suggested does not seem to work quite as expected. Now, nothing happens with a short press.
Hi again
It still does not work, but I think I'm getting there.
The problem with the code you suggested, is that _samplesTillHeld is defined as 0 (false) at the top.
Thus if (_samplesTillHeld) statement is never true, which is why no short press can ever be recognized.
I tried this instead, but it still does not work.
The idea is that the reloading of _sampleTillHeld only happens when an asserted press is performed and that the deasserted press only can occur if _sampleTillHeld is true (above zero, e.i. haven't been held for 2 seconds)
void isr(void) {
                    _samplesTillHeld = _samplesTillHeldReload;       // reload held samples only when asserted press
                if ( currentState != _assertValue && _samplesTillHeld ){    // _samplesTillHeld moved here
            else {
        else {
                _samplesTillHeld--;
                    else
            else {
I'm not entirely sure why the posted change didn't work.
_samplesTillHeld should be 0 normally since the button has been deasserted for more than the hold period. When the button is first pressed no asserted callback will be generated and _samplesTillHeld will be set to the timeout vale.
_samplesTillHeld then counts down. If the button is released before _samplesTillHeld reaches 0 the deasserted callback should be triggered. If the counter reaches 0 the asserted held callback is triggered and the next deasserted callback won't be generated.
Personally I would have said it would be far easier and cleaner to fix it in your code. Set a flag in sw2TransceiveMode_held, in sw2Frequency check the flag, if it's set then clear it and exit otherwise carry on as normal. I make that a total of 5 lines of code.
posted by Andy A 21 Sep 2015
Thank you for your help - definitely guided me in the right direction! I found a solution by modifying the library as you suggested. I believe it to be the best way to modify the library to operate in a way that I find intuitive (that is, do one thing on a short press, do another on a long press - to me this means "two buttons in one"). I always prefer not to have too many "Flag hacks" in my main code just to make it more readable.
EDIT: Mmm.. still not working as I want actually. Back to the drawing board.
EDIT EDIT: Oh well, this is becoming confusing, I made a simple mistake in my callback function, but, it actually works with the code I posted as a comment to my own question.
