10 years, 7 months ago.
I think that I2C Class is not ported to nRF51-DK
When I use the I2C function by the Keil Copiler library, it is working. But when I use the I2C Class, it is not working. When I assign the port to p7(scl) and p30(sda), they are all low states(maybe they are input). When I assigh the port to p6(scl) and p5(sda), they are all low states.
The example code is very simple. But there are no signal at each port.
<<code>>
I2C i2c(p28, p27);
int main() { int address = 0x62; char data[2]; i2c.read(address, data, 2); }
have you used pull up resistors? typically 2K ohm for 400Khz. i2c bus are 'open drain' are you measuring with an Oscilloscope?
posted by Martin Simpson 08 Sep 2015
I find out the problem that I missed the pull up resistors. Thanks alot for your advices.
posted by Kwang Sun Hong 09 Sep 2015
Hello Kwang,
In general you are correct. High level I2C commands (ones that require a data buffer) do not work well with the nRF51822. However, if you re-write your I2C commands using the more simplistic way, I found that those work well. You have to uses i2c.start, i2c.write(data0), i2c.write(data1), i2c.stop and so forth. Example:
//generic routine to get temp or humidity from HTU21D.
//Returns 14 bits of data (anded 0xFFFC) or 0000 if i2c timeout occurs.
//After a read temp or humidity command, HTU21D responds with NACKs until data is ready.
//NOTE: Use non-hold commands
uint16_t htu21d::getData(uint8_t reg) {
    int htu21cnt = 0;           //number of NACKs before ACK or timeout
    uint16_t htu21data = 0;     //returned data
    int htu21 = 0;              //ACK flag
    _i2c.start();
    htu21 = _i2c.write(HTU21Di2cWRITE);
    _i2c.write(reg);            //read temp, no hold
    _i2c.stop();
    if(htu21 == 0) return 0;    //HTU21T not responding
    do {
        htu21cnt++;
        _i2c.start();
        htu21 = _i2c.write(HTU21Di2cREAD);
        if(htu21 == 1) {
            htu21data = _i2c.read(1) << 8;
            htu21data |= _i2c.read(0) & 0xFC;
            _i2c.stop();
        wait_us(1000);
    } while((htu21cnt < 100) && (htu21 == 0));  //htu21cnt takes 55 to get temp, 16 for humidity (at 1mS loops)
    if(htu21 == 0) return 0;    //HTU21D ACK response timed out
    return(htu21data);          //return 14 bit value
