10 years, 6 months ago.
why can't I use the demo code?
I get permission denied on the code for this - why?
Everything should be public now, go ahead an give it a try.
I tested two CR20A's with K64F's and once I had worked out the menu system - easily performed some tests. Probably best to update the "help" page for that code as it has lots of useful functionality but its not clear how to use it (eg two serial terminals really helps) (https://developer.mbed.org/teams/Freescale/code/mcr20_connectivity_test/)
for the range test... On the Receiver (from "enter to start") Enter, 3 (range test), r (puts it into Rx mode), Space (starts receiving),
then on Transmitter node: Enter, 3, Space (as it defaults to Tx mode you don't have to change that),
you then see both terminals printing RSSI. My trick was to power the receiver with a Lithium bat pack on the second usb and walk away with it.
posted by Kirk Martinez 24 Jan 2016
The repository is currently defined as Private ,therefore that error. Once an owner is happy to release it, will be set to public.
