10 years, 7 months ago.
FRAM
Hello, I'm new to programming. Here I'm trying to store 3-axis vailues to FRAM. I could able to store string " hello world" . Now I'm trying to store 3-axis data. I failed to davalop the function. Could some one help me.
while (true) {
         accelerometer.getOutput(readings);
         pc.printf("\r\n%i, %i, %i", (int16_t)readings[0], (int16_t)readings[1], (int16_t)readings[2]);
         static char myString[] = "A Test String!\r\n";
         char readString[sizeof(myString)];
         int start = s.read_us();
         //Write bytes
         mem.writeBytes(myString,0,sizeof(myString));
         int writeEnd = s.read_us();
         //Read bytes
         mem.readBytes(readString,0,sizeof(readString));
         int end = s.read_us();
         //Print read bytes to Serial to verify correctness
         for (int i=0; i<sizeof(readString); i++) pc.printf("%c",readString[i]);
         pc.printf("\r\n");
         pc.printf("Write completed in %d microsecs.\r\n",writeEnd-start);
         pc.printf("Read completed in %d microsecs.\r\n",end-writeEnd);
         pc.printf("Status byte: 0x%x\r\n",mem.readStatusRegister());
         wait(0.5);
And the 3-axis readings function is
void ADXL345_I2C::getOutput(int* readings){
    char buffer[6];
    multiByteRead(ADXL345_DATAX0_REG, buffer, 6);
    readings[0] = (int)buffer[1] << 8 | (int)buffer[0];
    readings[1] = (int)buffer[3] << 8 | (int)buffer[2];
    readings[2] = (int)buffer[5] << 8 | (int)buffer[4];
Thank you.
I don't know the construct of your mem.writeBytes but appears to want a string
so you need to convert the Integer values into a string and then mem.writeByte that string
use sprintf() function
i.e.
char *newstring
/*do following three times n=0 to 2*/
sprintf(newstring,"%d",reading[n]);
mem.writeByte(newstring,0,sizeof(newstring));
Regards
posted by Martin Simpson 21 Aug 2015
Yes, It's working. thank you.
posted by Mohan gandhi Vinnakota 21 Aug 2015
I'm guessing that the format for readBytes and writeBytes are (void *, int offset, int length) in which case is should be as simple as:
    char buffer[6];
    char readBuffer[6];
    mem.writeBytes(buffer,0, 6);
    mem.readBytes(readBuffer,0,6);
    readings[0] = (int)readBuffer[1] << 8 | (int)readBuffer[0];
    readings[1] = (int)readBuffer[3] << 8 | (int)readBuffer[2];
    readings[2] = (int)readBuffer[5] << 8 | (int)readBuffer[4];
