10 years, 8 months ago.
How to connect multiple peripherals at same time ?
How can i modify this exemple to connect multiple leds at same time ?
Can I also be peripheral at same time ?
My goal is to use the full potential of S130 softdevice (1 central and 3 peripherals) assembling this exemple and the one called led.
Thank you.
You can extend the LEDBlinker to target multiple devices concurrently; each connection should come with a connectionHandle to help with the APIs.
It should also be possible to simultaneously be a peripheral. We aim to present a simple demo for this.
8 years, 1 month ago.
Hi Rohit,
Did you put a solution together for the multiple peripherals to one central as I am interested in the solution too.
Regards
Michael
+1
posted by ozan oner 26 May 2018
