10 years, 9 months ago.
callback to class - member function - can't quite make it work...
Hi C++ experts, I'm struggling. I found examples, none quite match my needs, so tried to derive a solution - but to no success.
The comments below reflect the compiler output.
class Callback {
public:
template <typename T> Callback(T * tptr, int (T::*mptr)(char * p), size_t allocsize) {
m_size = allocsize;
m_fp.attach(tptr, mptr);
// No instance of overloaded function mbed::FunctionPointerArg1::attach[with R=void]
// matches the argument list m_fp.attach(tptr, mptr);
void doit(void) {
int x = 3;
printf("size is %d\r\n", m_size);
x = m_fp.call("hello");
// Too many arguments in function call x = m_fp.call("hello");
// A value of type "void" cannot be assigned to an entity of type int x = m_fp.call("hello");
printf("callback returned %d\r\n", x);
private:
size_t m_size;
FunctionPointer m_fp;
class Worker {
public:
Worker() { }
int Process(char * p) {
printf("Process(%s)\r\n", p);
return 7;
Worker wk;
Callback cb(&wk, &Worker::Process, 75);
cb.doit();
Is it that "FunctionPointer" is restricted and it cannot match the signature of "int function(char *)"?
FunctionPointer only takes functions of type void function (void) There is an FPointer class https://developer.mbed.org/cookbook/FPointer that takes functions of type uint32_t function (uint32_t) which should do what you need if you cast the char* to a uint32_t. Or you could just create your own callback, it's not that complicated to do.
