10 years, 9 months ago.
Parsing strings with F401RE
Hello all;
First of all thank you who spend their valuable time to answer my (may be simple, foolish) questions before... Great support you provide here...
Now, I have some other questions following. I could solve easily this parsing problems with Arduino platfor with specific functions. I need some guidance, support for mbed...
1. I got a Rx string which stored in let say;
char buffer[20] =""
The string (data) from the sensor can be;
75 23.5 1235
or
12 24 237
or
9 9 43
etc
As you can see these numbers in string are space delimited and in different digit numbers.
I want to store them to different variables as integer or float... Any suggestions??
2. I want to parse the a string like
XXXX:12,23,456,12367,12
Similarly digits can be different but in these case all is integer. All numbers will be stored in different variables to compare or store ....
P.S. Is it a good choice to use std::string http://www.cplusplus.com/reference/string/string/ ? Timing is not important. The system can tolerate many milliseconds...
Thanks
Generally going for real strings is a bad idea on an MCU, that said the F401 has quite some resources, and if you don't need them anyway, you could use it.
However this seems all pretty straightforward stuff which works fine with char arrays. Have a look at for example: http://www.cplusplus.com/reference/cstdio/sscanf/. You can also split it first into seperate parts: http://www.cplusplus.com/reference/cstring/strtok/ together with http://www.cplusplus.com/reference/cstdlib/atoi/ and http://www.cplusplus.com/reference/cstdlib/atof/
I shall offend a lot of people, because I like C++ strings and vectors when the MCU has enough RAM.
Look at the "tokenizer" here :http://www.oopweb.com/CPP/Documents/CPPHOWTO/Volume/C++Programming-HOWTO-7.html, I use this code very often.
I hope this can help you.
BURN THE HERETIC!
No but I can see your point for an MCU like the F401, which indeed has quite some RAM and flash. That said at the same time his requirements are pretty straightforward, so I do wonder if it makes it significantly easier.
posted by Erik - 29 Jun 2015
