10 years, 9 months ago.
Why does this not work? - Serial Question..
From the pc i send serial data to sINPUT and expect it to send that data out of sOUTPUT
Serial cant send getc
Serial sOUTPUT(p9, p10);  // tx, rx
Serial sINPUT(USBTX, USBRX); // tx, rx
    sOutput.baud(921600);
    sINPUT.baud(921600);
    while (1)
        sOutput.printf(sINPUT.getc());
If you are using a windows pc, lower the baudrate to 460800.
The baud is fine, It's this line that's the problem
posted by . . 23 Jun 2015
The first parameter to printf should be a string. You are giving it an int.
You could try sOutput.printf("%c", sINPUT.getc()), but it might be more efficient to use putc and getc instead. There is an example of doing this in the Handbook Serial page.
Use putc rather than printf. printf expects a char* and you're passing it a char.
The alternative would be sOutput.printf("%c",sINPUT.getc());
but that would be about 20 times slower than putc for no benefit
