10 years, 5 months ago.
Where will I see the output?
The compilation of the program was successful. But I don't see the output.
have a look here:
https://developer.mbed.org/handbook/SerialPC
You can check SERIAL_TX/SERIAL_RX definitions in your micro's pinnames.h.
Or simply use Serial pc(USBTX, USBRX);
Then you can see the ouput from USB/USART port by TeraTerm or other utilities.
SERIAL_TX/RX are identcial to USBTX/USBRX. STM legacy issue (they didn't follow the standard, then they changed to the mbed standard, and then they decided to support both).
posted by 18 Jun 201510 years, 5 months ago.
I haven't used the Nucleo or the 'printf'. printf is used to display data to a serial terminal. You won't see it on a USB flash drive - that is a bulk storage device for files. [I haven't looked at the program itself - just going by the title and the other suggested answers] Your last post regarding the USB flashdrive is confusing. and needs clarification
I am using Mac OS X so I had to use a workaround, I just opened the Arduino IDE, selected the corresponding Serial Port and then used the Serial Monitor.
posted by Erik Arndt 22 Jun 2015Very good serial terminal for Mac OS http://freeware.the-meiers.org
posted by Dmitry Suhamera 22 Jun 2015
