10 years, 10 months ago.
mbed application board is not getting detected as a USB drive.
I have received mbed application board along with nxp 1768 mbed module.
1. NXP1768 mbed module is working fine, It is getting detected as USB drive in my MacBook, I am able to flash the *.bin. 2. When I insert the mbed module to mbed application board and then connect it to my MacBook host, it is not getting detected as usb drive.
Please provide information/solution if I am missing anything here.
If you can flash your bin file the the USB is working. Are you using the same USB connector on the LPC1768 after you plug it into your mbed application board, if not try it.
Yes I am using the same USB connector. Just mbed LPC1768, is getting detected in my MacBook, but once I insert the same module to mbed application board then connect the USB cable to my pc it is not getting detected.
posted by 17 Jun 2015yes Infact if i take out mbed module alone and flash it any program(say, print hello world on graphics lcd) and then insert the module back to mbed application board, the program runs fine, but only it won't detect as usb drive on my pc.
