10 years, 10 months ago.
console output over USB
Is it possible with the LPC11U35 to generate console output for debugging puposes? I mean something like the wiki entry for the Nucleo board with the following code-snippet:
Serial console( SERIAL_TX; SERIAL_RX ); console.printf( "Hello world\n" );
Is there a driver for a virtual COM Port?
Thanks in advance
Edit:
I tried 3 possibilities:
- the Windows Serial Configuration
- the USBSerial
- the LPC Link driver from NXT
Unfortunatly all of them failed.. Is it possible, that the pinnames in pinname.h are wrong regarding the USB-Pins?
Typically you should first connect the board and the PC using a USB cable, then install the regular mbed serial driver found here. The code on the LPC11U35 needs to use the USBDevice library. Import the lib from here.
Code is something like this:
#include "USBSerial.h"
//Virtual serial port over USB
USBSerial serial;
int main(void) {
while(1)
serial.printf("I am a virtual serial port\r\n");
wait(1);
Note: have not tried this on the 11U35 but it works on similar devices such as the 11U24. The LPC11U35 is used on the more recent NXP mbed platforms as the interface processor for drag-drop programming and also serves as USB-Serial converter with the serial driver referenced above.
Thank you for your answer. I just did some digging and found out, that your suggested solution apperently won't work here. Anyway I'll try the USBSerial library with a second USB-Plug
posted by 12 Jun 2015You dont need a second USB plug. The USB plug that is used for flashing new software should also be used for the USBSerial library. You will probably need to run a program that uses the USBSerial software (see example above) on the 11U35 before you can install the windows driver. The driver installer may not recognise the device when the USBSerial is not running. As stated in the other post, you can alternatively also use an external USB-Serial converter and save on memory space by not running the full USB stack on the 11U35. However, that seems strange since the U in 11U35 indicates that it is specifically intended for use as USB device.
posted by 12 Jun 201510 years, 10 months ago.
There is no serial over the USB as standard. You can use the USBSerial library as already suggested.
The other alternative is to use the uart on the LPC11U35 and a TTL level uart to USB adapter such as one of these: http://www.ftdichip.com/Products/Cables/USBTTLSerial.htm
This simplifies the code since only the base mbed libraries are needed but adds hardware complexity in that you have to wire the cable to pins P0_18,P0_19 and GND.
The code would be:
Serial console(UART_TX,UART_RX);
main() {
console.puts("Hello\r\n");
