11 years, 4 months ago.
i2c not working
Hi there,
I spent a lot of time to get the I2C interface working on the freescale FRDM-K64F (LPC1768 working fine) The demo's with the accelleration and compass are working without a problem. With a scope I see the data and clock. Using my own I2C routine, nothing is working, no signals on the pins stay high all the time. I know PTE24 and PTE25 should be reversed and frequency should be 400000.
there is a lot to be read on the mbed site, lots of people with problems, but I could not find a solution.
please help me, kind regards, Andries
The Freedom-K64F is an ultra-low-cost development platform for Kinetis K64, K63, and K24 MCUs.
Can you try the latest mbed-src ? There was a bugfix last week in I2C
posted by Martin Kojtal 18 Nov 2014
Or revert back to rev 89 of mbed.lib. I too wasted a whole day with i2c and rev 91
...kevin
posted by Kevin Braun 18 Nov 2014
thank you both for the comments. today i am out. tomorrow I will inform you about the results.
posted by andries oyens 19 Nov 2014
Dear Martin.
I am not sure how to work with the mbed-src files. I tried but got lots of errors like: Error: A value of type "void *" cannot be assigned to an entity of type "void " in "mbed-rtos/rtx/TARGET_CORTEX_M/rt_CMSIS.c", Line: 597, Col: 21 etc
Dear Kevin,
working with rev 89 did not do the trick. 91 gives errors with the EthernetInterface.
I like the FRDM-K64F a lot, but the I2C interface make me frustrated.Why is it so difficult???
cheers, Andries
src and rev 91 give errors with Ethernet Interface like Error: Too few arguments in invocation of macro "BW_MPU_CESR_VLD" in "EthernetInterface/lwip-eth/arch/TARGET_K64F/hardware_init_MK64F12.c", Line: 44, Col: 22
cheers, Andries
Hi there, i found a SOLUTION Stupid, but it works for me. 1-import FXOS8700Q lib and #include "FXOS8700Q.h" in main.cpp 2-add in main.cpp after I2C i2c(PTE25,PTE24); FXOS8700Q_acc acc( PTE25, PTE24, FXOS8700CQ_SLAVE_ADDR1); 3-in main() add: acc.enable(); acc.disable(); 4-now i2c.write() etc works !
hope it will help other people, cheers, Andries
11 years, 3 months ago.
I havn't checked the K64 but the K22 I2C lines shown on the mbed pin image are also mapped to the default uart driving the opensda communications channel. I would recommend insuring that the I2C pins you chose are not already defined? I have a K64 so I'll check it out the next couple of days - I have a variety of I2C chips to test against.
Scott
