11 years, 4 months ago.
Firmware Upgrade issue
Briefly:
Updated to rev 0203 from 0200, will not load bin file.
Back dated to rev 0201, will not load bin file.
Back dated to original rev 0200 working.
Tried the sequence again making sure files were unzipped, some are some are not. However I do end up with an Mbed drive every time.
Tried saving as a target directly to the board and saving as a file then copying to the board.
Checked PE drivers, however I do get the bootloader drive in any case and the Mbed firmware does load with Mbed resulting as a drive.
Tried on Two KL25Z boards, same result.
Using Windows 7, 64bit system. Mbed driver version 2.0.2.0
Other platforms working.
Any ideas?
Update:
I get 'SWD ERROR' in the fail.txt file on the Mbed drive
posted by Paul Staron 16 Nov 2014I am also seeing simular issue. I upgraded the BOOTloader to latest version 1.11. then i used the s19 file available in the mbed. I do not see binary running. Any one has the updated s19 file ?
posted by Jags K 25 Feb 2015
