10 years, 11 months ago.
Power consumption??
Hi.
I have an application that requires low power. The lowest I get is about 0.6mA in deepsleep. To my understanding it should be able to achieve a lower level (a few uAmps).
I have found there is a header in the hal library called STM32L1xx_hal_pwr_h, that provides some functions but I don't know how to use them properly...
Does anyone have an example or some info on how to reduce power consumption?
Thanks.
Followings are not direct answer for you but some hints.
posted by Kenji Arai 08 May 2015https://developer.mbed.org/users/kenjiArai/code/Nucleo_RTC_battery_bkup_pwr_off_okay/
In the SetRTC.lib, you will see void goto_standby(void) function.
You can modify clock on/off control and others.
https://developer.mbed.org/users/kenjiArai/code/SetRTC/file/ef7d2c83034d/SetRTC.cpp
In addition, you can see my BMP180 program at below.
http://www.page.sannet.ne.jp/kenjia/STM32L_w_PN2_baro.html
Sorry this is only Japanese but I have reached 16.5uA. total current at STOP mode.
