12 years, 3 months ago.
Can not open the mbed online compiler ?
I get the following error:
ERROR: Failed to initialize control objects. There has been an error opening your workspace. Please try again later or contact support.
OMG!!!! tomorrow lab session is thr...and it's not working!! :( have to write record..:(
posted by Daphny Oviya 08 Dec 2013
12 years, 2 months ago.
Hi All,
Yep, we're working on this now - sorry for the delay; our alerts didn't wake us up for some reason.
Service should resume shortly (or will keep you posted if there will be longer delays).
Thanks for reporting!
Simon
As dan posted on the forum, we are up and running again and all seems to be running fine the last 30 min.
Looks like one of our NetApp filers that was routine upgraded by our IT team over the weekend must have hit a problem (hence why things like the user icons weren't showing, and some of the resources needed for the compiler). Dan worked quickly with them to get it back functional again which is great; once we knew about it. But we'll have to investigate why we weren't automatically alerted and woken up that there were issues with the service - that is what actually caused the delay in our response, so sorry about that and we'll be investigating.
Please tell us if you see any more problems, but all should be back to normal!
Simon
posted by Simon Ford 08 Dec 2013
Same problem. Maybe they are doing software upgrade?
Perhaps so , I was able to successfully compile some programs an hour before and have just recently hit on this issue. I tried logging out and closing the browser but this did not resolve my issue
posted by ashok v 08 Dec 2013
Yo its down for us too
Same issue here for me. Probably some backend work from the mbed crew. Hopefully it gets fixed in the next hour or so; so much work to catch up on :( knew i should've exported and worked in keil instead :(
Edit: This is way too long. An admin needs to at least acknowledge this issue now, please!
Same problem cause to me. I want to carry out improvements as soon as you can. I use to plan enginnering education tomorrow. with Best Regards
Bummer, I wish they sent out a notice saying that work was going to be done.
same here
same to me too.
i confirm !
Hope this will be fixed the next hours.
Same issue here with all common browsers ...
Thats the drawback of an online compiler ... you rely on sombody else to fix you compiler installation issues on sunday mornings.
mbed crew should make an announcement before doing up-gradation so that we could schedule accordingly
same since 02:01 MEZ
same prolem for me, they should do this at night, or provide a real offline compiler soft that is click and run!
you do realize that night for some is day for others? but yeah it annoying we can't work on our code
posted by Mark Klarenbeek 08 Dec 2013
thank u for ur response now its ok
Mbed compiler not opening online today 22 Oct 2015
posted by Sunil Jha 22 Oct 2015
