11 years, 1 month ago.
Can I reuse LPC11U35 with mbed interface firmware for custom board?
On LPC812MAX, I found LPC11U35 with mbed interface firmware is used as a composite device including CMSIS-DAP, MSC as well as CDC/ACM.
Can I reuse the design in custom board?
I mean in technical as well as in license. Is it able to debug other hardware and is it allowed to port to other hardware?
11 years ago.
I have a question about the HDK. The schematic show a lpc11u35/501 (with 12kb Ram), should the HDK firmware works with a lpc11u35/401 (10kb Ram) ?
I searched in the doc but i can't find any information about the release needed.
Regards.
Patrick
I am waiting for my PCB to come back from print house, I hope it works !!
Paid for several boards & micros :{
posted by 15 Nov 2013I hope guys, you will share your outcome with us!
@Patrick Even if they are different (not familiar with those 2), you can always add new HAL for another target.
Regards, 0xc0170
posted by 15 Nov 201311 years, 1 month ago.
Hi kai,
We're working to be able to open source the mbed interface firmware within the next month, with exactly the idea you'll be able to use it on a custom board and modify it. Our plan is to put it under the permissive Apache 2.0 open source license so you'll be free to use it in commercial products without restriction.
We'll make builds available for simplicity, but the code being available will mean porting will be possible. I'm sure there will be some work needed to e.g. simplify porting, make it work in other toolchains than Keil MDK (which is what we currrently use to build it), so volunteers welcome!
Simon
11 years ago.
Relay (relay) stupid question:
Can I use the LPC800-MAX's LPC11U35 to program LPC1768 on custom bare metal PCB ??
Obviously removing LPC812,
I have a board I have just made, and need to speed up my development time, Flash Magic is OK for one off programming, but using the serial port on my board is becoming a pain !!
Cheers
Ceri
