12 years, 6 months ago.
Get status of connection to access point?
Briefly looking over the library API, I don't see a way to query the RN-XV for its connection status to an access point ( wireless router ).
Does this exist within the library at this time? Or does the library need to be extended to support a basic status() type method?
Jim
EDIT:
So after looking through some of the code in Wifly.h and Wifly.cpp I added the following method:
bool isAssociated()
return( state.associated );
So then to use in my application I have this small example:
while(1)
if( wifly.isAssociated() == true )
pc.printf("[%ld]Still connected....\r\n", connectCount++);
wait_ms(5000);
Does this seem like a reasonable change and does it do what I think it should be doing?
11 years, 10 months ago.
Hi Jim,
Your solution meets your needs I'm sure. I came across your post just now, and was looking at my own derived solution. It is a bit more complex than yours - my WiflyInterface has similar API "is_connected()". It actually quizzes the Wifly module for the current connection state. I didn't leave quite enough historical documentation to recall exactly why I did that (an older version was much more like what you suggested).
