file rename
13 Aug 2010 . Edited: 13 Aug 2010
is the rename function broken?
I call "rename(/fs/old, /fs/new);" however the code is never executed and "-1" is always returned.  The rename is called on a FileFystemLike child class object called FS instantiated with the name "filesys".  The rename function is defined in this child class and should be executed when the wrapper function is called, however the code is completely skipped and -1 is returned.
This way of defining virtual functions in the child class and calling them with wrapper functions works with open, opendir, remove, etc. but not rename.  Is there something I overlooked or does anyone know why?
some code:
#include "fschild.h"
int main
    fschild FS("filesys");
    FILE *fp = fopen("/filesys/test.txt", "w");
    fprintf(fp, "Hello, World!");
    fclose(fp);
    //remove("/filesys/test.txt");  it works
    //rename("/filesys/test.txt", "/filesys/test2.txt");  it returns -1 always
snippet from mbed FileSystemLike.h
class FileSystemLike : public Base {
public:
    /* Function remove
     *  Remove a file from the filesystem.
     * Variables
     *  filename - the name of the file to remove.
     *  returns - 0 on success, -1 on failure.
    virtual int remove(const char *filename) { return -1; };
    /* Function rename
     *  Rename a file in the filesystem.
     * Variables
     *  oldname - the name of the file to rename.
     *  newname - the name to rename it to.
    virtual int rename(const char *oldname, const char *newname) { return -1; };
snippets from my code:
class fschild : public FileSystemLike
    public:
        fschild(const char* SystemName);
        virtual FileHandle* open(const char* filename, int flags);
        virtual int remove(const char* filename);
        virtual int rename(const char* oldname, const char* newname);
int fschild::remove(const char* filename)
    char FileName[64];
    sprintf(FileName, "%d:/%s", Drive, filename);
    if (f_unlink((const TCHAR*)FileName))
        return -1;
    else
        return 0;
int fschild::rename(const char* oldname, const char* newname)
    char OldName[64];
    sprintf(OldName, "%d:/%s", Drive, oldname);
    if (f_rename((const TCHAR*)OldName, (const TCHAR*)newname))
        return -1;
    else
        return 0;
 @ Simon, I'm almost done getting full functionality from the FAT File System, this is the last bug!  Let me know how you would like to be credited for your work, right now I am only keeping your old comments at the top.  Thanks again for all of the help, the FATFileSystem has indeed become very useful.
23 Aug 2010
Bumping this thread
Is there work still being done on stdio::rename?  No matter what I try, it will always return -1.
I even changed the virtual FileSystemLike function to only execute "return 0"; yet it still returns -1.  I've checked everything so many times, I must give up soon.  Is there any information on this?
the code:SDCard
Sincere thanks to anyone who can help.
Thomas
