Important update: Arm Announces End of Life Timeline for Mbed. This site will be archived in July 2026. Read the full announcement.
What is the online compiler tool?
![](/media/cache/img/default_profile.jpg.16x16_q85_crop-center.jpg)
You cannot use that notation to refer to integers in C. As far as I know you can only chars (i.e. 'a'), hexadecimal (i.e 0xA5D3), or octal (i.e. 0x721) notations to represent integral constants. I am not sure about C++.
You should convert all the binary constants to either hex or decimal. Hex would be easier because each nibble in a binary word corresponds to a digit in hex.
Hope that helps.
OK, I started it earlier, but the problem is that a bitmap for an lcd is encoded in this format... hundreds of bytes... I would be happy if I wouldn't have to rewrite all byte to hex. :SIgor Martinovski wrote:
Hope that helps.
An easier change may a simple BinToHex convertor routine. Here's a simple, naive version, which could be improved on in various ways:
uint32_t BinToHex(const char *bin) { uint32_t hexval = 0; uint8_t bit; int i = 0; int len; len = strlen(bin); while((i < 32) && (i < len)) { bit = (bin[i] - 48) & 0x1; // 48 being ASCII '0' hexval = (hexval << 1) | bit; i++; } return(hexval); }
Pass in a string of '1' and ''0' characters, and it hands you back the unsigned 32 bit number. It can of course be optimised, but it demonstrates the concept.
Maybe a little late, but arduino uses a binary.h file for this purpose. it goes like this:
binary.h from arduino
#ifndef Binary_h #define Binary_h #define B0 0 #define B00 0 #define B000 0 #define B0000 0 #define B00000 0 #define B000000 0 #define B0000000 0 #define B00000000 0 #define B1 1 #define B01 1 #define B001 1 #define B0001 1 #define B00001 1 #define B000001 1 #define B0000001 1 #define B00000001 1 #define B10 2 #define B010 2 #define B0010 2 #define B00010 2 #define B000010 2 #define B0000010 2 #define B00000010 2 #define B11 3 #define B011 3 #define B0011 3 #define B00011 3 #define B000011 3 #define B0000011 3 #define B00000011 3 #define B100 4 #define B0100 4 #define B00100 4 #define B000100 4 #define B0000100 4 #define B00000100 4 #define B101 5 #define B0101 5 #define B00101 5 #define B000101 5 #define B0000101 5 #define B00000101 5 #define B110 6 #define B0110 6 #define B00110 6 #define B000110 6 #define B0000110 6 #define B00000110 6 #define B111 7 #define B0111 7 #define B00111 7 #define B000111 7 #define B0000111 7 #define B00000111 7 #define B1000 8 #define B01000 8 #define B001000 8 #define B0001000 8 #define B00001000 8 #define B1001 9 #define B01001 9 #define B001001 9 #define B0001001 9 #define B00001001 9 #define B1010 10 #define B01010 10 #define B001010 10 #define B0001010 10 #define B00001010 10 #define B1011 11 #define B01011 11 #define B001011 11 #define B0001011 11 #define B00001011 11 #define B1100 12 #define B01100 12 #define B001100 12 #define B0001100 12 #define B00001100 12 #define B1101 13 #define B01101 13 #define B001101 13 #define B0001101 13 #define B00001101 13 #define B1110 14 #define B01110 14 #define B001110 14 #define B0001110 14 #define B00001110 14 #define B1111 15 #define B01111 15 #define B001111 15 #define B0001111 15 #define B00001111 15 #define B10000 16 #define B010000 16 #define B0010000 16 #define B00010000 16 #define B10001 17 #define B010001 17 #define B0010001 17 #define B00010001 17 #define B10010 18 #define B010010 18 #define B0010010 18 #define B00010010 18 #define B10011 19 #define B010011 19 #define B0010011 19 #define B00010011 19 #define B10100 20 #define B010100 20 #define B0010100 20 #define B00010100 20 #define B10101 21 #define B010101 21 #define B0010101 21 #define B00010101 21 #define B10110 22 #define B010110 22 #define B0010110 22 #define B00010110 22 #define B10111 23 #define B010111 23 #define B0010111 23 #define B00010111 23 #define B11000 24 #define B011000 24 #define B0011000 24 #define B00011000 24 #define B11001 25 #define B011001 25 #define B0011001 25 #define B00011001 25 #define B11010 26 #define B011010 26 #define B0011010 26 #define B00011010 26 #define B11011 27 #define B011011 27 #define B0011011 27 #define B00011011 27 #define B11100 28 #define B011100 28 #define B0011100 28 #define B00011100 28 #define B11101 29 #define B011101 29 #define B0011101 29 #define B00011101 29 #define B11110 30 #define B011110 30 #define B0011110 30 #define B00011110 30 #define B11111 31 #define B011111 31 #define B0011111 31 #define B00011111 31 #define B100000 32 #define B0100000 32 #define B00100000 32 #define B100001 33 #define B0100001 33 #define B00100001 33 #define B100010 34 #define B0100010 34 #define B00100010 34 #define B100011 35 #define B0100011 35 #define B00100011 35 #define B100100 36 #define B0100100 36 #define B00100100 36 #define B100101 37 #define B0100101 37 #define B00100101 37 #define B100110 38 #define B0100110 38 #define B00100110 38 #define B100111 39 #define B0100111 39 #define B00100111 39 #define B101000 40 #define B0101000 40 #define B00101000 40 #define B101001 41 #define B0101001 41 #define B00101001 41 #define B101010 42 #define B0101010 42 #define B00101010 42 #define B101011 43 #define B0101011 43 #define B00101011 43 #define B101100 44 #define B0101100 44 #define B00101100 44 #define B101101 45 #define B0101101 45 #define B00101101 45 #define B101110 46 #define B0101110 46 #define B00101110 46 #define B101111 47 #define B0101111 47 #define B00101111 47 #define B110000 48 #define B0110000 48 #define B00110000 48 #define B110001 49 #define B0110001 49 #define B00110001 49 #define B110010 50 #define B0110010 50 #define B00110010 50 #define B110011 51 #define B0110011 51 #define B00110011 51 #define B110100 52 #define B0110100 52 #define B00110100 52 #define B110101 53 #define B0110101 53 #define B00110101 53 #define B110110 54 #define B0110110 54 #define B00110110 54 #define B110111 55 #define B0110111 55 #define B00110111 55 #define B111000 56 #define B0111000 56 #define B00111000 56 #define B111001 57 #define B0111001 57 #define B00111001 57 #define B111010 58 #define B0111010 58 #define B00111010 58 #define B111011 59 #define B0111011 59 #define B00111011 59 #define B111100 60 #define B0111100 60 #define B00111100 60 #define B111101 61 #define B0111101 61 #define B00111101 61 #define B111110 62 #define B0111110 62 #define B00111110 62 #define B111111 63 #define B0111111 63 #define B00111111 63 #define B1000000 64 #define B01000000 64 #define B1000001 65 #define B01000001 65 #define B1000010 66 #define B01000010 66 #define B1000011 67 #define B01000011 67 #define B1000100 68 #define B01000100 68 #define B1000101 69 #define B01000101 69 #define B1000110 70 #define B01000110 70 #define B1000111 71 #define B01000111 71 #define B1001000 72 #define B01001000 72 #define B1001001 73 #define B01001001 73 #define B1001010 74 #define B01001010 74 #define B1001011 75 #define B01001011 75 #define B1001100 76 #define B01001100 76 #define B1001101 77 #define B01001101 77 #define B1001110 78 #define B01001110 78 #define B1001111 79 #define B01001111 79 #define B1010000 80 #define B01010000 80 #define B1010001 81 #define B01010001 81 #define B1010010 82 #define B01010010 82 #define B1010011 83 #define B01010011 83 #define B1010100 84 #define B01010100 84 #define B1010101 85 #define B01010101 85 #define B1010110 86 #define B01010110 86 #define B1010111 87 #define B01010111 87 #define B1011000 88 #define B01011000 88 #define B1011001 89 #define B01011001 89 #define B1011010 90 #define B01011010 90 #define B1011011 91 #define B01011011 91 #define B1011100 92 #define B01011100 92 #define B1011101 93 #define B01011101 93 #define B1011110 94 #define B01011110 94 #define B1011111 95 #define B01011111 95 #define B1100000 96 #define B01100000 96 #define B1100001 97 #define B01100001 97 #define B1100010 98 #define B01100010 98 #define B1100011 99 #define B01100011 99 #define B1100100 100 #define B01100100 100 #define B1100101 101 #define B01100101 101 #define B1100110 102 #define B01100110 102 #define B1100111 103 #define B01100111 103 #define B1101000 104 #define B01101000 104 #define B1101001 105 #define B01101001 105 #define B1101010 106 #define B01101010 106 #define B1101011 107 #define B01101011 107 #define B1101100 108 #define B01101100 108 #define B1101101 109 #define B01101101 109 #define B1101110 110 #define B01101110 110 #define B1101111 111 #define B01101111 111 #define B1110000 112 #define B01110000 112 #define B1110001 113 #define B01110001 113 #define B1110010 114 #define B01110010 114 #define B1110011 115 #define B01110011 115 #define B1110100 116 #define B01110100 116 #define B1110101 117 #define B01110101 117 #define B1110110 118 #define B01110110 118 #define B1110111 119 #define B01110111 119 #define B1111000 120 #define B01111000 120 #define B1111001 121 #define B01111001 121 #define B1111010 122 #define B01111010 122 #define B1111011 123 #define B01111011 123 #define B1111100 124 #define B01111100 124 #define B1111101 125 #define B01111101 125 #define B1111110 126 #define B01111110 126 #define B1111111 127 #define B01111111 127 #define B10000000 128 #define B10000001 129 #define B10000010 130 #define B10000011 131 #define B10000100 132 #define B10000101 133 #define B10000110 134 #define B10000111 135 #define B10001000 136 #define B10001001 137 #define B10001010 138 #define B10001011 139 #define B10001100 140 #define B10001101 141 #define B10001110 142 #define B10001111 143 #define B10010000 144 #define B10010001 145 #define B10010010 146 #define B10010011 147 #define B10010100 148 #define B10010101 149 #define B10010110 150 #define B10010111 151 #define B10011000 152 #define B10011001 153 #define B10011010 154 #define B10011011 155 #define B10011100 156 #define B10011101 157 #define B10011110 158 #define B10011111 159 #define B10100000 160 #define B10100001 161 #define B10100010 162 #define B10100011 163 #define B10100100 164 #define B10100101 165 #define B10100110 166 #define B10100111 167 #define B10101000 168 #define B10101001 169 #define B10101010 170 #define B10101011 171 #define B10101100 172 #define B10101101 173 #define B10101110 174 #define B10101111 175 #define B10110000 176 #define B10110001 177 #define B10110010 178 #define B10110011 179 #define B10110100 180 #define B10110101 181 #define B10110110 182 #define B10110111 183 #define B10111000 184 #define B10111001 185 #define B10111010 186 #define B10111011 187 #define B10111100 188 #define B10111101 189 #define B10111110 190 #define B10111111 191 #define B11000000 192 #define B11000001 193 #define B11000010 194 #define B11000011 195 #define B11000100 196 #define B11000101 197 #define B11000110 198 #define B11000111 199 #define B11001000 200 #define B11001001 201 #define B11001010 202 #define B11001011 203 #define B11001100 204 #define B11001101 205 #define B11001110 206 #define B11001111 207 #define B11010000 208 #define B11010001 209 #define B11010010 210 #define B11010011 211 #define B11010100 212 #define B11010101 213 #define B11010110 214 #define B11010111 215 #define B11011000 216 #define B11011001 217 #define B11011010 218 #define B11011011 219 #define B11011100 220 #define B11011101 221 #define B11011110 222 #define B11011111 223 #define B11100000 224 #define B11100001 225 #define B11100010 226 #define B11100011 227 #define B11100100 228 #define B11100101 229 #define B11100110 230 #define B11100111 231 #define B11101000 232 #define B11101001 233 #define B11101010 234 #define B11101011 235 #define B11101100 236 #define B11101101 237 #define B11101110 238 #define B11101111 239 #define B11110000 240 #define B11110001 241 #define B11110010 242 #define B11110011 243 #define B11110100 244 #define B11110101 245 #define B11110110 246 #define B11110111 247 #define B11111000 248 #define B11111001 249 #define B11111010 250 #define B11111011 251 #define B11111100 252 #define B11111101 253 #define B11111110 254 #define B11111111 255 #endif
I would like to ask if somebody knows what compiler is used if I compile my project online? In my project there are constants in binary format (e.g. 0b00000001) and the compiler says: >>Expected a "}"<< just before the letter 'b'. Anyway, is there a documentation available about the compiler?
Thanks,
Balint
