What is the online compiler tool?
27 Mar 2010
I would like to ask if somebody knows what compiler is used if I compile my project online? In my project there are constants in binary format (e.g. 0b00000001) and the compiler says: >>Expected a "}"<< just before the letter 'b'. Anyway, is there a documentation available about the compiler?
Balint
28 Mar 2010
Keil, mbed is an ARM project, Keil is owned by ARM.
01 Apr 2010 . Edited: 01 Apr 2010
You cannot use that notation to refer to integers in C. As far as I know you can only chars (i.e. 'a'), hexadecimal (i.e 0xA5D3), or octal (i.e. 0x721) notations to represent integral constants. I am not sure about C++.
You should convert all the binary constants to either hex or decimal. Hex would be easier because each nibble in a binary word corresponds to a digit in hex.
Hope that helps.
07 Apr 2010
Hope that helps.
OK, I started it earlier, but the problem is that a bitmap for an lcd is encoded in this format... hundreds of bytes... I would be happy if I wouldn't have to rewrite all byte to hex. :S
08 Apr 2010
An easier change may a simple BinToHex convertor routine. Here's a simple, naive version, which could be improved on in various ways:
uint32_t BinToHex(const char *bin)
    uint32_t hexval = 0;
    uint8_t bit;
    int i = 0;
    int len;
    len = strlen(bin);
    while((i < 32) && (i < len))
        bit = (bin[i] - 48) & 0x1;      // 48 being ASCII '0'
        hexval = (hexval << 1) | bit;
        i++;
    return(hexval);
Pass in a string of '1' and ''0' characters, and it hands you back the unsigned 32 bit number. It can of course be optimised, but it demonstrates the concept.
29 Apr 2013
Maybe a little late, but arduino uses a binary.h file for this purpose. it goes like this:
binary.h from arduino
#ifndef Binary_h
#define Binary_h
#define B0 0
#define B00 0
#define B000 0
#define B0000 0
#define B00000 0
#define B000000 0
#define B0000000 0
#define B00000000 0
#define B1 1
#define B01 1
#define B001 1
#define B0001 1
#define B00001 1
#define B000001 1
#define B0000001 1
#define B00000001 1
#define B10 2
#define B010 2
#define B0010 2
#define B00010 2
#define B000010 2
#define B0000010 2
#define B00000010 2
#define B11 3
#define B011 3
#define B0011 3
#define B00011 3
#define B000011 3
#define B0000011 3
#define B00000011 3
#define B100 4
#define B0100 4
#define B00100 4
#define B000100 4
#define B0000100 4
#define B00000100 4
#define B101 5
#define B0101 5
#define B00101 5
#define B000101 5
#define B0000101 5
#define B00000101 5
#define B110 6
#define B0110 6
#define B00110 6
#define B000110 6
#define B0000110 6
#define B00000110 6
#define B111 7
#define B0111 7
#define B00111 7
#define B000111 7
#define B0000111 7
#define B00000111 7
#define B1000 8
#define B01000 8
#define B001000 8
#define B0001000 8
#define B00001000 8
#define B1001 9
#define B01001 9
#define B001001 9
#define B0001001 9
#define B00001001 9
#define B1010 10
#define B01010 10
#define B001010 10
#define B0001010 10
#define B00001010 10
#define B1011 11
#define B01011 11
#define B001011 11
#define B0001011 11
#define B00001011 11
#define B1100 12
#define B01100 12
#define B001100 12
#define B0001100 12
#define B00001100 12
#define B1101 13
#define B01101 13
#define B001101 13
#define B0001101 13
#define B00001101 13
#define B1110 14
#define B01110 14
#define B001110 14
#define B0001110 14
#define B00001110 14
#define B1111 15
#define B01111 15
#define B001111 15
#define B0001111 15
#define B00001111 15
#define B10000 16
#define B010000 16
#define B0010000 16
#define B00010000 16
#define B10001 17
#define B010001 17
#define B0010001 17
#define B00010001 17
#define B10010 18
#define B010010 18
#define B0010010 18
#define B00010010 18
#define B10011 19
#define B010011 19
#define B0010011 19
#define B00010011 19
#define B10100 20
#define B010100 20
#define B0010100 20
#define B00010100 20
#define B10101 21
#define B010101 21
#define B0010101 21
#define B00010101 21
#define B10110 22
#define B010110 22
#define B0010110 22
#define B00010110 22
#define B10111 23
#define B010111 23
#define B0010111 23
#define B00010111 23
#define B11000 24
#define B011000 24
#define B0011000 24
#define B00011000 24
#define B11001 25
#define B011001 25
#define B0011001 25
#define B00011001 25
#define B11010 26
#define B011010 26
#define B0011010 26
#define B00011010 26
#define B11011 27
#define B011011 27
#define B0011011 27
#define B00011011 27
#define B11100 28
#define B011100 28
#define B0011100 28
#define B00011100 28
#define B11101 29
#define B011101 29
#define B0011101 29
#define B00011101 29
#define B11110 30
#define B011110 30
#define B0011110 30
#define B00011110 30
#define B11111 31
#define B011111 31
#define B0011111 31
#define B00011111 31
#define B100000 32
#define B0100000 32
#define B00100000 32
#define B100001 33
#define B0100001 33
#define B00100001 33
#define B100010 34
#define B0100010 34
#define B00100010 34
#define B100011 35
#define B0100011 35
#define B00100011 35
#define B100100 36
#define B0100100 36
#define B00100100 36
#define B100101 37
#define B0100101 37
#define B00100101 37
#define B100110 38
#define B0100110 38
#define B00100110 38
#define B100111 39
#define B0100111 39
#define B00100111 39
#define B101000 40
#define B0101000 40
#define B00101000 40
#define B101001 41
#define B0101001 41
#define B00101001 41
#define B101010 42
#define B0101010 42
#define B00101010 42
#define B101011 43
#define B0101011 43
#define B00101011 43
#define B101100 44
#define B0101100 44
#define B00101100 44
#define B101101 45
#define B0101101 45
#define B00101101 45
#define B101110 46
#define B0101110 46
#define B00101110 46
#define B101111 47
#define B0101111 47
#define B00101111 47
#define B110000 48
#define B0110000 48
#define B00110000 48
#define B110001 49
#define B0110001 49
#define B00110001 49
#define B110010 50
#define B0110010 50
#define B00110010 50
#define B110011 51
#define B0110011 51
#define B00110011 51
#define B110100 52
#define B0110100 52
#define B00110100 52
#define B110101 53
#define B0110101 53
#define B00110101 53
#define B110110 54
#define B0110110 54
#define B00110110 54
#define B110111 55
#define B0110111 55
#define B00110111 55
#define B111000 56
#define B0111000 56
#define B00111000 56
#define B111001 57
#define B0111001 57
#define B00111001 57
#define B111010 58
#define B0111010 58
#define B00111010 58
#define B111011 59
#define B0111011 59
#define B00111011 59
#define B111100 60
#define B0111100 60
#define B00111100 60
#define B111101 61
#define B0111101 61
#define B00111101 61
#define B111110 62
#define B0111110 62
#define B00111110 62
#define B111111 63
#define B0111111 63
#define B00111111 63
#define B1000000 64
#define B01000000 64
#define B1000001 65
#define B01000001 65
#define B1000010 66
#define B01000010 66
#define B1000011 67
#define B01000011 67
#define B1000100 68
#define B01000100 68
#define B1000101 69
#define B01000101 69
#define B1000110 70
#define B01000110 70
#define B1000111 71
#define B01000111 71
#define B1001000 72
#define B01001000 72
#define B1001001 73
#define B01001001 73
#define B1001010 74
#define B01001010 74
#define B1001011 75
#define B01001011 75
#define B1001100 76
#define B01001100 76
#define B1001101 77
#define B01001101 77
#define B1001110 78
#define B01001110 78
#define B1001111 79
#define B01001111 79
#define B1010000 80
#define B01010000 80
#define B1010001 81
#define B01010001 81
#define B1010010 82
#define B01010010 82
#define B1010011 83
#define B01010011 83
#define B1010100 84
#define B01010100 84
#define B1010101 85
#define B01010101 85
#define B1010110 86
#define B01010110 86
#define B1010111 87
#define B01010111 87
#define B1011000 88
#define B01011000 88
#define B1011001 89
#define B01011001 89
#define B1011010 90
#define B01011010 90
#define B1011011 91
#define B01011011 91
#define B1011100 92
#define B01011100 92
#define B1011101 93
#define B01011101 93
#define B1011110 94
#define B01011110 94
#define B1011111 95
#define B01011111 95
#define B1100000 96
#define B01100000 96
#define B1100001 97
#define B01100001 97
#define B1100010 98
#define B01100010 98
#define B1100011 99
#define B01100011 99
#define B1100100 100
#define B01100100 100
#define B1100101 101
#define B01100101 101
#define B1100110 102
#define B01100110 102
#define B1100111 103
#define B01100111 103
#define B1101000 104
#define B01101000 104
#define B1101001 105
#define B01101001 105
#define B1101010 106
#define B01101010 106
#define B1101011 107
#define B01101011 107
#define B1101100 108
#define B01101100 108
#define B1101101 109
#define B01101101 109
#define B1101110 110
#define B01101110 110
#define B1101111 111
#define B01101111 111
#define B1110000 112
#define B01110000 112
#define B1110001 113
#define B01110001 113
#define B1110010 114
#define B01110010 114
#define B1110011 115
#define B01110011 115
#define B1110100 116
#define B01110100 116
#define B1110101 117
#define B01110101 117
#define B1110110 118
#define B01110110 118
#define B1110111 119
#define B01110111 119
#define B1111000 120
#define B01111000 120
#define B1111001 121
#define B01111001 121
#define B1111010 122
#define B01111010 122
#define B1111011 123
#define B01111011 123
#define B1111100 124
#define B01111100 124
#define B1111101 125
#define B01111101 125
#define B1111110 126
#define B01111110 126
#define B1111111 127
#define B01111111 127
#define B10000000 128
#define B10000001 129
#define B10000010 130
#define B10000011 131
#define B10000100 132
#define B10000101 133
#define B10000110 134
#define B10000111 135
#define B10001000 136
#define B10001001 137
#define B10001010 138
#define B10001011 139
#define B10001100 140
#define B10001101 141
#define B10001110 142
#define B10001111 143
#define B10010000 144
#define B10010001 145
#define B10010010 146
#define B10010011 147
#define B10010100 148
#define B10010101 149
#define B10010110 150
#define B10010111 151
#define B10011000 152
#define B10011001 153
#define B10011010 154
#define B10011011 155
#define B10011100 156
#define B10011101 157
#define B10011110 158
#define B10011111 159
#define B10100000 160
#define B10100001 161
#define B10100010 162
#define B10100011 163
#define B10100100 164
#define B10100101 165
#define B10100110 166
#define B10100111 167
#define B10101000 168
#define B10101001 169
#define B10101010 170
#define B10101011 171
#define B10101100 172
#define B10101101 173
#define B10101110 174
#define B10101111 175
#define B10110000 176
#define B10110001 177
#define B10110010 178
#define B10110011 179
#define B10110100 180
#define B10110101 181
#define B10110110 182
#define B10110111 183
#define B10111000 184
#define B10111001 185
#define B10111010 186
#define B10111011 187
#define B10111100 188
#define B10111101 189
#define B10111110 190
#define B10111111 191
#define B11000000 192
#define B11000001 193
#define B11000010 194
#define B11000011 195
#define B11000100 196
#define B11000101 197
#define B11000110 198
#define B11000111 199
#define B11001000 200
#define B11001001 201
#define B11001010 202
#define B11001011 203
#define B11001100 204
#define B11001101 205
#define B11001110 206
#define B11001111 207
#define B11010000 208
#define B11010001 209
#define B11010010 210
#define B11010011 211
#define B11010100 212
#define B11010101 213
#define B11010110 214
#define B11010111 215
#define B11011000 216
#define B11011001 217
#define B11011010 218
#define B11011011 219
#define B11011100 220
#define B11011101 221
#define B11011110 222
#define B11011111 223
#define B11100000 224
#define B11100001 225
#define B11100010 226
#define B11100011 227
#define B11100100 228
#define B11100101 229
#define B11100110 230
#define B11100111 231
#define B11101000 232
#define B11101001 233
#define B11101010 234
#define B11101011 235
#define B11101100 236
#define B11101101 237
#define B11101110 238
#define B11101111 239
#define B11110000 240
#define B11110001 241
#define B11110010 242
#define B11110011 243
#define B11110100 244
#define B11110101 245
#define B11110110 246
#define B11110111 247
#define B11111000 248
#define B11111001 249
#define B11111010 250
#define B11111011 251
#define B11111100 252
#define B11111101 253
#define B11111110 254
#define B11111111 255
#endif
13 Mar 2015
Danke :D
13 Mar 2015
Josef Kager wrote:
WTF thainutte
