Of course, actual mbed version of the library is based in the old Maniacbug RF24 library and it is only developed for Nucleo platform. New library is created from the abandoned Maniacbug library being a forck of the mbed one, offering new interesting features, It has some sub librearies non compiler dependent (I was talking with the developer and said me that the only dependent is RF24 being the core driver) such us RF24Network (I will copy and paste):
Dual headed operation: The use of dual radios for busy routing nodes or the master node enhances throughput and decreases errors. See the Tuning section.
Extended timeouts and staggered timeout intervals. The new txTimeout variable allows fully automated extended timeout periods via auto-retry/auto-reUse of payloads.
Optimization to the core library provides improvements to reliability, speed and efficiency. See https://tmrh20.github.io/RF24 for more info.
Built in sleep mode using interrupts. (Still under development. (Enable via RF24Network_config.h))
Host Addressing. Each node has a logical address on the local network.
Message Forwarding. Messages can be sent from one node to any other, and this layer will get them there no matter how many hops it takes.
Ad-hoc Joining. A node can join a network without any changes to any existing nodes.
And RF24Mesh offering:
Basic 'mesh' functionality using an Arduino or RPi as the master node which will generally receive the sensor data
Simple, dynamic addressing based on a pre-assigned unique identifier
Dynamic/On-the fly configuration of addresses and network topology
Other sublibraries are RF24Audio for audio streaming and some more...
Mbed RF24 library doesn't support theese sublibraries and it is only avalible for Nucleo, offering just basic talking between radios. Talking with the developer of this new library based in the old one, said me that there is only the need of porting RF24 library (sublibrarries realy in RF24, not platform or compiler), and he added a template to get it easier. (http://tmrh20.github.io/RF24/Portability.html)
I feel that creating an autoconfigurable mesh network with 1$ radios is quite interesting for IoT. Well, not true mesh but close enough, more info here http://tmrh20.github.io/RF24Network/
This is an awesome RF 2.4GHz from Nordic. There are some mbed libraries, but, for me, the best library, is this one for arduino and RPi http://tmrh20.github.io/RF24/
some of the most important features are here http://tmrh20.github.io/RF24Network/ and mesh capabilities. Every library depends from http://tmrh20.github.io/RF24/
Recently the creator researched an easy way to port it http://tmrh20.github.io/RF24/Portability.html
I am not quite good in programing so I would like some one helping me to port it to lpc820.
Thanks
