With my friend's help, we have figured it out.
Just to share you all. Here is the MCP3008 datasheet. http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010530
Here is the code.
#include "TextLCD.h"
SPI _spi(p5,p6,p7); //mosi, miso, sck
DigitalOut cs(p8); // chip select of MCP3008
TextLCD lcd(p24, p25, p26, p27, p28, p29, p30); // rs, rw, e, d0, d1, d2, d3
int _data1;
int _data2;
cs=1; // deselect everything
wait(0.001);
_spi.format(8,0); //see page1 of MCP3008 manual
_spi.frequency(1000000); //see page4 of MCP3008 manual
// MCP3008 clock sequence and control bits
//Once cs low, send start bit ==> 0x01 Not expecting any return
//next, send control bits Expecting return B9, B8
//next, send anything, say 0x00, expecting return B7-B0
//next shift B9,B8 left 8bits
//next merge B9,B8 and B7-B0 to form 16bits data
//next, mask off bit15-bit10, to get a clean 10 bit data
// 1st 8bits 2nd 8bits 3rd 8bits
//ch0 0x01 0x80 0x00
//ch1 0x01 0x90 0x00
//ch2 0x01 0xA0 0x00
//ch3 0x01 0xB0 0x00
//ch4 0x01 0xC0 0x00
//ch5 0x01 0xD0 0x00
//ch6 0x01 0xE0 0x00
//ch7 0x01 0xF0 0x00
while (1) {
//ch0.
cs=0; //cs low. start data collection
_spi.write(0x01); //write start bit. Not expecting return
_data1=_spi.write(0x80); //write control bit, expecting return B9, B8
_data2=_spi.write(0x00); //write anything, expecting return B7-B0
int ch0 =(_data1<<8) | _data2; //merge two 8bits data becoming 16bits data
ch0 = ch0 & 0x03FF; // mask off bit15 - bit10
cs=1; //cs high. end of data collection
//ch1
cs=0;
_spi.write(0x01);
_data1=_spi.write(0x90);
int ch1 =(_data1<<8) | _data2;
ch1 = ch1 & 0x03FF;
cs=1;
//ch2
cs=0;
_spi.write(0x01);
_data1=_spi.write(0xA0);
int ch2 =(_data1<<8) | _data2;
ch2 = ch2 & 0x03FF;
cs=1;
//ch3
cs=0;
_spi.write(0x01);
_data1=_spi.write(0xB0);
int ch3 =(_data1<<8) | _data2;
ch3 = ch3 & 0x03FF;
cs=1;
//ch4
cs=0;
_spi.write(0x01);
_data1=_spi.write(0xC0);
int ch4 =(_data1<<8) | _data2;
ch4 = ch4 & 0x03FF;
cs=1;
//ch5
cs=0;
_spi.write(0x01);
_data1=_spi.write(0xD0);
int ch5 =(_data1<<8) | _data2;
ch5 = ch5 & 0x03FF;
cs=1;
//ch6
cs=0;
_spi.write(0x01);
_data1=_spi.write(0xE0);
int ch6 =(_data1<<8) | _data2;
ch6 = ch6 & 0x03FF;
cs=1;
//ch7
cs=0;
_spi.write(0x01);
_data1=_spi.write(0xF0);
int ch7 =(_data1<<8) | _data2;
ch7 = ch7 & 0x03FF;
cs=1;
//Display the results
lcd.cls();
lcd.locate(0,0);
lcd.printf("%d%d%d%d",ch0,ch1,ch2,ch3);
lcd.locate(0,1);
lcd.printf("%d%d%d%d",ch4,ch5,ch6,ch7);
wait(0.01);
Dear all,
I have connected P5,P6,P7, P8 to Din, Dout, CLK and CS of MCP3008. (I wonder it is correct)
I use format(8,0) rather than (8,1). (actually both format are able to display outputs)
I have tried with http://mbed.org/handbook/SPI, but could not interpret the output 0x??. What is 0x?
How do I know which anlog inputs from MCP3008, I intended to read.?
cheers
