Serial.Attach
01 Feb 2010
It would be nice to get interrupt notifications when the serial port has writing a byte or the output queue is empty in addition to when a byte is received.
01 Feb 2010
Hi Eli,
Thanks; ticketed. We'll look at a nice way of doing this.
If you have a particular use case that you could provide some pseudo-code for that would be useful (i.e. write a program as if it existed, to demonstrate the way you'd like to use it).
Thanks!
Simon
02 Feb 2010
Here is my current code.    I have my own large software byte queues for Tx and Rx.    I can use the Rx interrupt to fill my incoming byte queue byte but need a ticker to periodcally check to see if I can move data from my software queue to the tx hardware:
//*****************************  Code Start
#include"System.h"
ByteQueue PCBackDoorTx,PCBackDoorRx;
BYTE PCBackDoorTx_Queue_Storage[PC_BACKDOOR_QUEUE_SIZE];
BYTE PCBackDoorRx_Queue_Storage[PC_BACKDOOR_QUEUE_SIZE];
Serial PCBackDoor(USBTX, USBRX);
Ticker PCBackDoorTxQueueCheck;
//IRQ for when data is received
void PCBackDoorRxIRQ();
void InitPCBackDoor()
InitByteQueue(&PCBackDoorTx,PC_BACKDOOR_QUEUE_SIZE,&PCBackDoorTx_Queue_Storage[0]);
InitByteQueue(&PCBackDoorRx,PC_BACKDOOR_QUEUE_SIZE,&PCBackDoorRx_Queue_Storage[0]);
PCBackDoor.baud(57600);
PCBackDoor.format(8,Serial::None,1);
//The Rx IRQ wil fill up my big software Rx Queue
PCBackDoor.attach(PCBackDoorRxIRQ);
//Periodicically check my outgoing Tx Queue (every 10 mS)
PCBackDoorTxQueueCheckTicker.attach_us(&PCBackDoorMoveTxQueue,10000);
void PCBackDoorMoveTxQueue()
BYTE Temp;
while(PCBackDoor.writeable())
if(BytesInQueue(&PCBackDoorTx) == 0)
break;
else
ByteDequeue(&PCBackDoorTx,&Temp);
PCBackDoor.putc(Temp);
while(PCBackDoor.readable())
ByteEnqueue(&PCBackDoorRx,(BYTE)PCBackDoor.getc());
//************************Code end
What I would like is some sort of notification that the last transmission has been completed so I don't need the periodic timer calls to poll to see if the serial port is writeable.
