Thanks Simon.
I'm using Chris Styles plan for Prototype to Hardware to port and upgrade some LPC2103 projects to the LPC1768, but I'm planning to do this in three steps. (1) Main PCB with socket for mbed module. (2) LPC1768 only module to replace mbed (3) New main PCB with LPC1768 built in.
The 'Main PCB' has a FPGA and some I/O stuff on it.
I have written and tested some of the code require using the mbed libraries and compiler with TXD0 and RXD0 as my ASCII communication port. Problem is I cannot do ISP for step (2) using Flash Magic unless I at minimum install a USB socket and the associated Rs and Cs on the 'LPC1768 Only' module. I can do that but what about the Virtual Comm Port USB driver for the PC link to Flash Magic? Can I use a driver that is part of the mbed tool kit?
Why am I going to all this trouble? The two key features for jogging me into the LPC2103 to LPC1768 migration are NVIC and QEI. Unfortunately the three pins required for QEI P1.20, P1.23, and P1.24 are not pinned out on mbed. My solution is to add a 5-pin connector and a 74LS14 as the encoder interface at the opposite end of the 'LPC1768 Only' module to the end used for the mbed USB connector.
If the VCP USB driver issue is not too hard, and I get my 'LPC1768' Only module built, then I will be asking how do I implement QEI with the mbed libraries and compiler?
Thanks for any help you can provide.
John
How do I match the mbed serial port designations (p28,p27 etc) with the LPC1768 UART names (UART0 etc)?
