I'm trying to use a DAC (Cirrus Logic CS4344) with I2S that requires a Master Clock input. As far as I understand the mbed (LPC1768) schematic, TX_MCLK is not available on any of the DIP headers. Do you think it's possible to simulate TX_MCLK by setting up an I2S receiver in master mode (with I2SRX_CLK set to the same frequency as required by TX_MCLK) beside the I2S transmitter and use I2SRX_CLK (DIP 30) as the master clock input on the DAC?
So the configuration would be as follows:
Is there any other way to interface with an I2S DAC without an external master clock?
