I observe that port pin p29 does not work, although it is configured correctly as DigitalOut. However, other pins work as they should.
When I do a short test program, which switches all pins, everything works - my mbed seems not to be defective...
Is it possible that use of two I2C interfaces (p27,p28 as I2C slave) prevents the simultaneous use of p29?
p30 is working properly, for example ...
I've already checked several times to confirm whether all pins are initialized, but the compiler gives no error message - so I hope that someone here has an explanation?
(the error occurs on naked mbed too, only with plugged USB cable - so I don't think something is wrong with the rest of my circuit...)
Ok - I couldn't fall asleep unless a last try to fix it; it was the simpe fact of using the name of a variable twice... Although having searched for all occurences in my code i forgot to look in the header file...
Now it works - good night!! :-)
Michael
I observe that port pin p29 does not work, although it is configured correctly as DigitalOut. However, other pins work as they should.When I do a short test program, which switches all pins, everything works - my mbed seems not to be defective...Is it possible that use of two I2C interfaces (p27,p28 as I2C slave) prevents the simultaneous use of p29?p30 is working properly, for example ...I've already checked several times to confirm whether all pins are initialized, but the compiler gives no error message - so I hope that someone here has an explanation? (the error occurs on naked mbed too, only with plugged USB cable - so I don't think something is wrong with the rest of my circuit...)Ok - I couldn't fall asleep unless a last try to fix it; it was the simpe fact of using the name of a variable twice... Although having searched for all occurences in my code i forgot to look in the header file... Now it works - good night!! :-)
Michael
