compass HMC6352 trouble
26 Dec 2011
Just received the compass module. Can't get it to work. Below is a snippet of code.
#include "HMC6352.h"
//HMC6352 compass(p9, p10);
Serial pc(USBTX, USBRX);
wait(10);
pc.printf("Starting HMC6352 test...\r\n");
This will print on serial terminal, but if I uncomment HMC6352, it will not. If I unplug the module, it will not print either. Maybe the module is defective?
17 Apr 2014
Just tried mine, it read 5268.40000 and never changed.
17 Apr 2014
My bad had pins wrong, works fine now
06 May 2014
What is your conection diagram? did you use PTE0 and PTE1 ports?
06 May 2014
Because im getting the same 5268.40000 value
You need to log in to post a reply
