FlashIAP Erase function STM32
13 Mar 2018
Hi, I'm trying to develope a bootloader application for my stm32f401 board, starting from mbed-bootloader-example.
I want to update the firmware via UART serial port.
I can successfully compile application+bootloader and program it via stlink. The bootloader mbed_start_application works well and the main application start. But if I try to write a new firmware by bootloader I got problem.
My problem is that FlashIAP Erase function always fails.
Does anyone found solution ?
Please help
/media/uploads/gpingv/main.cpp
15 Mar 2018
Following the bootloader tutorial I've setted
    "target_overrides": {
		"NUCLEO_F401RE": {
            "target.restrict_size": "0x20000"
but when I compile (GCC_ARM)
Using regions in this build:
  Region bootloader size 0x1ff00, offset 0x8000000
  Region application size 0x60100, offset 0x801ff00
Region bootloader size is wrong, it must be 0x20000, as specified in mbed_app.json file. In this way it's not possible to align sector for erasing/program operation
