Version control for user programs
23 Nov 2009
I used the simplest/stupidest way to do the version control by naming programs like Foo_V1 and Foo_V2. But along with more and more projects and more and more versions, my "Program Workspace" is a mess.
I tried to use "sub-folders" for the version control like
However, the compiler will compile the both main.cpp files in V1 and V2, and complains multiple defined functions.
To work around this, I modify the main.cpp in V1 and V2 as
main.cpp in V1
#include "version.h"
#ifdef V1
#endif
and
main.cpp in V2
#ifdef V2
#endif
Then add a version.h to define the version V1 or V2
#define V1
The work-around works. But I am wondering if there is more straight forward, elegant way to do the version control?
Best regards,
Paul
23 Nov 2009
You can use cookbook SVN. Some people also requested support for their own SVN servers, maybe it will be implemented.
23 Nov 2009
Thank you Igor. But I would like to keep my programs private instead of publishing them to Cookbook.
