USB Driver Serial for fourth serial in MBED
28 Apr 2011
Somebody use the USB interface of MBED pin 31 (D+) and 32 (D-) to link a device USB with emulate a serial (SPARKFUN DEV-08245 Nike+iPod Serial to USB Adapter) because my 3 others interface are used by others device
thank for your help.
28 Apr 2011
I assume you want to use the LPC1768's USB. Then you will need to implement USB CDC. so far, I don't think this has been made available, Even though it is a reasonable simple implementation. I know Code red compiler has it, but not MBED :'(
As with basic hid device. Unfortunately, I have not got Either to work.
Cheers
Ceri.
02 May 2011
You can use an SPI to UART device like the Max3100 if you need more UARTS. I currently have a breakout board on order which I made for myself, happy to share if you are interested.
Serge
02 May 2011
and if you use a MAX3100 I have published a simple library that makes one or more MAX3100 devices appear just like a standard Mbed Serial object.
Import libraryMAX3100
MAX3100, an external serial device to add additional serial ports via SPI
