hear is my code for:
LTC1660 Eight Channel and
LTC2630 Single channel.
<>Code
- include "mbed.h"
DigitalOut myled1(LED1);
DigitalOut myled2(LED2);
DigitalOut myled3(LED3);
DigitalOut myled4(LED4);
SPI spi (p5, p6, p7); mosi, miso, sclk
DigitalOut LTC_1660_CS (p22);
DigitalOut LTC_1660_CLR (p21);
DigitalOut LTC_2630_CS (p23);
Serial pc(USBTX, USBRX);
AnalogIn Therm1(p15);
void LTC1660_Set_DAC_Value (char Channel, int Value);
void LTC2630_Set_DAC_Value (int Value);
void GetTemperatyre (void);
int Pattern = 22;
pc.baud(921600);
pc.format(8,Serial::None,1);
pc.printf ("\r\nIt Lives ..."); Serial pc(USBTX, USBRX);
set up LTC 1660 .. Vout = 0 ...
force LTC1660 ADC's Low ..
LTC_2630_CS = 1;
LTC_1660_CS = 1;
LTC_1660_CLR = 1; wait_ms (50);
LTC_1660_CLR = 0; wait_ms (50);
LTC1660_Set_DAC_Value (2, 0);
LTC2630_Set_DAC_Value (0);
wait (0.5);
myled1 = 1;
while(1)
while (++Pattern < 1000) 40% of 3.3V = 1.32V, R sens = 1.65 Ohms (3R3 || 3R3)
LTC1660_Set_DAC_Value (2, Pattern);
LTC2630_Set_DAC_Value (Pattern);
wait_ms (5.0);
myled1 = 1;
myled4 = 0;
myled1 = 0;
myled2 = 1;
wait (2.50);
GetTemperatyre();
while (Pattern > 1)
wait_ms (5.0);
myled2 = 0;
myled3 = 1;
GetTemperatyre();
myled3 = 0;
myled4 = 1;
wait (1.50);
myled4 = 0;
wait (5.50);
myled2 = 0;
myled3 = 0;
myled4 = 0;
GetTemperatyre();
int OUT = 0;
check ranges ..
Channel &= 0x07;
Channel ++;
if (Value > 0x03ff) Value = 0x03ff ;
joine together ..
OUT = Channel;
OUT = OUT << 10;
OUT |= Value;
OUT = OUT << 2;
set all channels ..
OUT |= 0xf000;
send (as 2 bytes)
LTC_1660_CS = 0;
spi.write (OUT >> 0x08);
spi.write (OUT & 0xff);
LTC_1660_CS = 1;
int OUT = 0;
check ranges ..
joine together ..
OUT = Value;
OUT = OUT << 6;
send (as 2 bytes)
LTC_2630_CS = 0;
spi.write (0x30);
LTC_2630_CS = 1;
float T_ADC = Therm1.read();
float C, C3;
11.239x2 - 61.705x + 94.628
T_ADC = T_ADC * 3.3;
C = ((11.239 * (T_ADC*T_ADC)) - (61.705 * T_ADC)) + 94.628;
C3 =(-12.727*(T_ADC*T_ADC*T_ADC))+(69.111*(T_ADC*T_ADC))-(140.49*T_ADC)+123.77;
printf ("Temp ADC Value = %3.6f - %3.6f Deg C - Third Order .. %3.6f Deg C\r\n",T_ADC, C, C3);
sorry cannot remember how to mark up code snippets
Hello Everyone
I am trying to setup and use an AD5666 SPI quad DAC chip. The datasheet is here http://www.analog.com/static/imported-files/data_sheets/AD5666.pdf
I have tried the program below and I get nothing out on any of the DAC channels. I dont see what I am doing wrong?? I tried changing the SPI mode to 0-3 with no change in results. Please take a look and offer any thoughts as I'm stumped for now.
#include "mbed.h" /* ________AD5666_______ GND--| !LDAC SCLK|-- MBED PIN7 MBED PIN29--| !SYNC DIN |-- MBED PIN5 3.3V--|VDD GND|-- GND NC --|DACA DACB|--NC NC --|DACC DACD|--NC GND--|POR !CLR|--3.3V 3.3V--|_Vref__________SDO_|--MBED PIN6 */ SPI DAC(p5,p6,p7); //mosi PIN13 on chip, miso PIN8 on chip, sck PIN14 on DAC chip DigitalOut cs(p29); // chip select of DAC pin2 Serial pc(USBTX, USBRX); int main() { pc.baud(115200); cs=1; // deselect everything wait(0.1); DAC.format(16,1); //16bit word X2, mode 1 SPI?? DAC.frequency(1000000); cs=0; wait(0.1); //cs low. // 31 0 DAC.write(0x04FF); //write 0000 0100 1111 1111 1111 1100 1111 1111 to power on all DACs? DAC.write(0xFCFF); cs=1; //cs high. end of data collection wait(0.2); while (1) { cs=0; //cs low. wait(0.1); // 31 0 DAC.write(0x010F); //write 0000 0001 0000 1111 1111 1111 1111 0000 to output full DAC chA?? DAC.write(0xFFF0); cs=1; //cs high. end of data collection wait(1); }
