Important changes to forums
We’re making some changes to the Mbed forums. From 10th December 2019 all new discussions will take place on our new forum site. You can continue to reply to existing threads for the next two weeks. After that we will archive this forum so you can return to useful posts in the future.
LCD 2x16
19 Jan 2010
Outl4w - wrote:
Hi Vlad, thanks,  the lcd don't work still with your code, but your idea i think it's good. I will go on trying and share my code with you.
Make sure you connect the TX pin to the RX pin on the mbed, and the RX to the TX on the mbed, not TX>TX, RX>RX
19 Jan 2010 . Edited: 19 Jan 2010
Yes, RX pin on the LCD Chip to TX on Mbed. Chip has not Tx pin.
are you testing with your LCD? it works?
Thanks.
19 Jan 2010
I just setup a similar project using the SerLCD built in on my LCD screen. You can see what I did here:Display on Sparkfun SerLCD v2.5 and here Setting the Bootsplash on Sparkfun's SerLCD v.2.5
20 Jan 2010
Thx ! all working!
For my 4 line by 20 character LCDs I need to use this code for locate:
            switch (_row) {
                case (0) : address = 0x80 + _column;
                break;
                case (1) : address = 0xc0 + _column;
                break;
                case (2) : address = 0x94 + _column;
                break;
                case (3) : address = 0xd4 + _column;
                break;
This is because it prints row0 first, then row2, then row1, then row3.
Scott
26 May 2011
Mr Simon,
We have connected LCD AC-162BYA-H to the mbed. We used your HelloWorld code, but it's not working. Pin connections are made properly. We added DC power supply of 5V, but still not working.
22 Sep 2015
Mr Simon. I have connected lcd 16*2 to mbed lpc 1768 power supply and pin connection properly but I required display move left right continues in c plus plus programming code not work please help me.
22 Sep 2015
Mr simon ,
I not seen the pwm out put on screen pc with using tera term.
You need to log in to post a reply
