SOLVED: I'm retarded, forgot the extra = in the if statement. Left posted code uncorrected.
I'm trying to write a mbed serial interface to read data output from CH robotics new UM6 AHRS/IMU.
http://www.chrobotics.com/docs/UM6_datasheet.pdf
So far I've gotten thru recognizing the "snp" (start new packet) string with the mbed.
The next packet/byte sent by the UM6 is called the PT byte. This byte contains a bunch of information
which depends on which bits are set, but this byte is always the same value for the default UM6 setup.
The byte is 0xC8, but when I try to use getc() in any way with this byte the program either freezes or
gives me the compile error: Expression must be a modifiable lvalue (E137)
I know its probably some property of getc() that I don't know about.
Could anyone help out and tell me why getc() won't work, and what alternative I can use.
I knew I get stuck on the bitshifting part because the UM6 transmits 16 bit signed int as two 8 bit int,
but I didn't think I would get stuck on something this simple.
Here's my work so far, with the resulting error already stated at the 0xC8 if statement.
Serial pc(USBTX, USBRX);
Serial uart(p28, p27);
DigitalOut pc_activity(LED1);
DigitalOut uart_activity(LED2);
int state = 0;
// set serial uart baud 115200
uart.baud(115200);
// set pc baud 115200
pc.baud(115200);
int packet_state = 0; // STATE OF PACKET, ZERO = WAIT FOR 'snp'
while(packet_state == 0) {
// pc.putc(uart.getc()); // Serial pass thru
// READ 'snp' (START NEW PACKET) FROM UM6 AHRS
if (uart.getc() == 0x73 ) {
// pc.putc(0x73);
pc.putc('s');
state = 1;
if (uart.getc() == 0x6E ) {
// pc.putc(0x6E);
pc.putc('n');
state ++;
// uart_activity = !uart_activity;
if (uart.getc() == 0x70 ) {
// pc.putc(0x70);
pc.putc('p');
state ++;
// PT (packet type)
if (uart.getc() = 0xC8 ) {
state = 0;
pc.putc('P');
pc.putc('T');
state ++;
I'm trying to write a mbed serial interface to read data output from CH robotics new UM6 AHRS/IMU. http://www.chrobotics.com/docs/UM6_datasheet.pdf
The next packet/byte sent by the UM6 is called the PT byte. This byte contains a bunch of information which depends on which bits are set, but this byte is always the same value for the default UM6 setup.
The byte is 0xC8, but when I try to use getc() in any way with this byte the program either freezes or gives me the compile error: Expression must be a modifiable lvalue (E137)
I knew I get stuck on the bitshifting part because the UM6 transmits 16 bit signed int as two 8 bit int, but I didn't think I would get stuck on something this simple.
#include "mbed.h" Serial pc(USBTX, USBRX); Serial uart(p28, p27); DigitalOut pc_activity(LED1); DigitalOut uart_activity(LED2); int state = 0; int main() { // set serial uart baud 115200 uart.baud(115200); // set pc baud 115200 pc.baud(115200); int packet_state = 0; // STATE OF PACKET, ZERO = WAIT FOR 'snp' while(packet_state == 0) { // pc.putc(uart.getc()); // Serial pass thru // READ 'snp' (START NEW PACKET) FROM UM6 AHRS if (uart.getc() == 0x73 ) { // pc.putc(0x73); pc.putc('s'); state = 1; } if (uart.getc() == 0x6E ) { // pc.putc(0x6E); pc.putc('n'); state ++; // uart_activity = !uart_activity; } if (uart.getc() == 0x70 ) { // pc.putc(0x70); pc.putc('p'); state ++; // uart_activity = !uart_activity; } // PT (packet type) if (uart.getc() = 0xC8 ) { state = 0; pc.putc('P'); pc.putc('T'); state ++; } } }
