Eagle Library for the HANRUN HR911105A
30 Jan 2011
Hi , Does someone have an Eagle LIbrary for the magjack manufactured by HANRUN model HR911105A ? Can you share your library ? Thanks in advance . Jeronimo http://blogdoje.com.br
/media/uploads/jeroavf/hanrun_hr911105a.jpg
30 Jan 2011
Why not create it yourself? It would only take a few minutes with the PCB software I use, and shouldn't take much longer with Eagle. I found the data sheet here:
http://www.terraelectronica.ru/pdf/HANRUN/HR911105A.pdf
It has the relevant dimensions.
01 Feb 2011
Thanks for your suggestion, I agree with you that it is simple to construct it, but if it exists in an opensource form , it will be better and quicker to use/improve it and go direct to my project. I have found it in a Dangerous Prototype opensource project, http://dangerousprototypes.com/2009/12/11/prototype-web-platform/ , extracted it and started to use. Regards, Jeronimo http://blogdoje.com.br
06 Feb 2011
Hi , I am adding the Eagle library with the HANRUN HR911105A magnetics to this post. I hope that it be useful to other mBed users. /media/uploads/jeroavf/connecter.lbr.zip Jeronimo. http://blogdoje.com.br
