mbed hangs on serial interrupt
11 Sep 2015
Hello
I'm trying to catch data from the serial ports (p9, p10) and (p13, p14). I want it interrupt based, But my mbed hangs afther initialisation.
First I've the initialization functions:
void SerialA_Init(int baud)
    serial_A.baud(baud);
    serial_A.attach(&RxA_interrupt);
void SerialB_Init(int baud)
    serial_B.baud(baud);
    serial_B.attach(&RxB_interrupt);
Then in the callback functions I try to catch the data:
void RxA_interrupt(void)
    char data = serial_A.getc();
    rcvBufferA = rcvBufferA + data;
void RxB_interrupt(void)
    char data = serial_B.getc();
    rcvBufferB = rcvBufferB + data;
To actually use the data I use another function that uses the rcvBufferA and B.
But the problem is, when booting the MBED, it initializes the serial ports and then the MBED freezes. I've tried several possible solutions like adding "UART_1_RBR = LPC_UART1->RBR;" But nothing works.
How can I solve this?
Thanks Robin
11 Sep 2015
So what is in your program happening after it initializes the serial port? Are you using RTOS?
11 Sep 2015
Yes, I use the EthernetInterface library to handle TCP/IP communication.
When I receive a serial message, it should send it to the server through TCP/IP
14 Sep 2015
It al works fine when I'm not using the "serial_A.attach(&RxA_interrupt);" lines, If I use them "Setting up Ethernet..." is not written to my console. So i suppose it hangs afther the initialisation...
11 Sep 2015
While it only should hang once called, you are not allowed to use Serial interrupts when using RTOS. Use RawSerial instead, then it is allowed.
11 Sep 2015
Is there any example, how to use RawSerial interrupt based?
Thanks for the quick support
11 Sep 2015
Yes. Replace 'Serial' with 'RawSerial' in the declaration of your serial connection, and it should work :).
11 Sep 2015
It does not...
Still hangs after initialization.
Declaration
RawSerial serial_A(p9,p10);
RawSerial serial_B(p13,p14);
init
interrupt routine
    while(serial_A.readable())
       char karakt = serial_A.getc();
        rcvBufferA = rcvBufferA + karakt;
    while(serial_B.readable())
       char karakt = serial_B.getc();
        rcvBufferB = rcvBufferB + karakt;
also tried, not using "strings" in the interrupt callback, as suggested here: https://developer.mbed.org/questions/60528/RawSerial-Rx-interrupt-only-triggering-o/ same result..
Regards
Robin
11 Sep 2015
Do you have any reason to assume it hangs due to the interrupts? And try to figure out where it hangs (you can even use LEDs which light up when you enter the interrupt routine, or just print something to serial).
11 Sep 2015
I've created an simple program. Code below. I also included the rtos library but haven't used it.
Now it seems that the interrupt problem is solved. (for now) But, I want to print a message in terminal A when there are more then 5 characters received.
I receive on both ports that "they are alive" but when i send some characters it seems not responding... So i never get the message "A index > 5" or "B index > 5".
#include <iostream>
#include <string>
char bufferA[100];
char bufferB[100];
int bufA_index, bufB_index;
       bufA_index++;
       bufB_index++;
    serial_A.printf("program started \r\n");
    serial_A.printf("interrupts attached \r\n");
        wait(1);
        if (bufA_index > 5)
            serial_A.printf("A index > 5");
            bufA_index = 0;
        if (bufB_index > 5)
            serial_A.printf("B index > 5");
            bufB_index = 0;
        serial_A.printf("I'm still alive! \r\n");
        serial_B.printf("Also alive! \r\n");
11 Sep 2015
Any variable modified in an interrupt routine needs to be defines as 'volatile' to make sure the main loop uses always the most recent version. This is especially true for the index integers (so set them as volatile int), but also the buffers themselves should be defined as volatile.
Btw if you include rtos lib in your program, assume it is used :). Not 100% sure about it, but I have seen weird stuff with it.
11 Sep 2015
Dear Erik,
Thanks for the support. I finally found my mistake, and it's an hardware issue :( (I use an custom board based on the LPC1768)
But the info about the interrupts is very useful. On Monday i'll try to fix the hardware issue and then I can continue to program.
I'll keep you posted!
Regards Robin
12 Sep 2015
Robin,
Your simple two interrupt program can show some interesting issues. Although you are not using an rtos you have effectively created a very simple rtos with the interrupt dispatcher acting as scheduler. When viewed in this way you have built a 3 task system with shared variables - bufA_index and bufB_index. The asynchronous nature of interrupt arrival will mean that you cannot predict the actual order of execution.
In your design you are also making an assumption that clearing and incrementing these shared variables are indivisible (also called atomic) operations and cannot be interrupted. This may or may not be true. If they are not indivisible then you can get some very interesting bugs where you will lose counts.
As regards using the 'volatile' keyword, I have always assumed that this only ensured that the variable was left alone be the code optimiser. I don't think it can ensure mutual exclusive access.
Jim
14 Sep 2015
Dear Erik, Jim
I fixed the hardware issue, implemented the serial interrupts as suggested earlier, and it works fine!
Thanks for the support!
15 Sep 2015
Glad to hear it, good luck with your project.
You need to log in to post a reply
