Inline assembly to .s-file
11 Dec 2010 . Edited: 11 Dec 2010
I came across these two inline assembly functions below that are not being compiled with the online compiler. Hence I tried to rewrite them as an s-File following this Cookbook answer.
But I am not quite experienced with assembly and sure about how to pass the parameters and if the result is returned correctly.
I'd appreciate it, if someone could have a look at it :)
Thank you very much in advance,
Moritz
Edit: Sorry, I just saw, that this question fits maybe better to the "Hello World!"-forum?!
static __inline__ int MULSHIFT32(int x, int y)
int zlow;
__asm__ volatile ("smull %0,%1,%2,%3" : "=&r" (zlow), "=r" (y) : "r" (x), "1" (y) : "cc");
return y;
  AREA asm_func, CODE, READONLY
; Export my_asm function location so that C compiler can find it and link
    EXPORT MULSHIFT32
MULSHIFT32
; ARM Assembly language function to describe the following inline assembly function:
; function call: extern "C" static int MULSHIFT32(int x, int y);
; --> R0 = x; R1 = y;
;  smull RdLo, RdHi, Rn, Rm [:= RdHi, RdLo = Rn * Rm]
; return RdHi
; calculate Signed MULtiply Long
        SMULL R1, R0, R0, R1
; Return to C using link register (Branch and change instruction set)
	BX   LR
        END
typedef union _U64
	long long w64;
	struct{
		unsigned int lo32;
		signed int hi32;
	} r;
} U64;
static __inline long long MADD64(long long sum64, int x, int y)
	U64 u;
	u.w64 = sum64;
	__asm__ volatile ("smlal %0,%1,%2,%3" : "+&r" (u.r.lo32), "+&r" (u.r.hi32) : "r" (x), "r" (y) : "cc");
	return u.w64;
    EXPORT MADD64
MADD64
; function call: extern "C" static long long MADD64(long long sum64, int x, int y)
; --> R0, R1 = sum64 (R0 = lo32, R1 = hi32); R2 = x, R3 = y;
;  smlal RdLo, RdHi, Rn, Rm [:= RdHi,RdLo = signed(RdHi,RdLo + Rm * Rs)]
; return RdLo, RdHi
; calculate Signed MuLtiply and Accumulate Long
	SMLAL R0, R1, R2, R3
	BX    LR
        END
11 Dec 2010
Looks okay to me. Are there errors when compiling? Note that you can just use 64-bit vars in your program. It's very likely the compiler will use these instructions for matching operations.
Thank you for your reply.
64-bit variables are fine. I suppose there aren't any longer ones.
Edit: Ah, yes it is compiling fine. I was just unsure if there could happen any errors with wrong register etc. :)
11 Dec 2010
One question still remains. There is no chance to keep these functions inline, isn't it?
