Hi Dave,
Any way to swap \n and \r? Just started playing with the serial ports via Serial.printf() and noticed that mbed is using the DOS equivalents for \n and \r (as opposed to the Unix/Linux defaults)
Looking at http://en.wikipedia.org/wiki/Newline, there are 3 (2 common) ways for line endings:
- LF - Unix, Mac OSX
- CR+LF - DOS, Windows
- CR - Old Mac
Our preference in code is to use the Unix/Mac OSX format of just LF (\n) in code. On the Windows platform, most terminal apps can set the line ending to just LF, and many programs use this anyway.
We don't modifying any behaviour here. i.e. LF and CR characters just pass through as per normal. So whilst we recommend you do:
printf("hello\n"); // prefered line ending
and you should just get a LF out, you can also do:
printf("hello\r\n"); // discouraged line ending
you should get CR+LF. As I said, the preference to keep the code the same across platforms is just to use \n, and change the terminal settings on DOS/Windows to recognise that.
Here is a test program I just wrote to play with showing loopback on a serial port, putting out characters using putc and printf, and reading back the raw result. Main aim was to prove no manipulation of line ending characters:
Basically, we try not to do any magic around line endings. If you are seeing different behaviour, or have any ideas/suggestions, please shout.
Thanks,
Simon
Any way to swap \n and \r? Just started playing with the serial ports via Serial.printf() and noticed that mbed is using the DOS equivalents for \n and \r (as opposed to the Unix/Linux defaults). Any way to programmatically change this?
