Hi Y'all,
New to mbed, tho not to embedded systems :)>
I'm attempting to use the interrupt driven features of the serial API as shown in the following code. The LED keeps blinking but I never see any activity on the serial port. I've previously had success using the polled interface so I'm pretty confident that I've got things hooked up properly. My theory is that the UART transmit buffer empty interrupt service routine is never being invoked. I have no idea why.
#include "pc-serial.h"
DigitalOut alive_led(LED1);
PCSerial pc_serial;
char c = '!';
while (1) {
alive_led = 1;
wait(0.2);
pc_serial.Putc(c);
alive_led = 0;
wait(0.2);
c = (c + 1) & 0x7f;
if (c<=0) c = '!';
#include "LPC17xx.h"
class PCSerial {
private:
static const int outbuf_size = 32;
static const int pointer_mask = 0x1f;
char outbuf[outbuf_size];
volatile int wp, rp;
bool overflow;
void TxISR(void);
void enableTxIrq(void);
void disableTxIrq(void);
public:
PCSerial(void);
void Putc(char c);
bool isOverflow() {return overflow;};
Serial pc(USBTX, USBRX);
PCSerial::PCSerial(void) {
// init the serial port
pc.baud(115200);
pc.format(8, Serial::None, 1);
// init the output FIFO
wp = 0; rp = 0;
// Attach a member function to call whenever a transmit buffer empty
// interrupt is generated
pc.attach(this, &PCSerial::TxISR, Serial::TxIrq);
disableTxIrq(); // initially disabled since the output FIFO is empty
// Copy the input byte to the output buffer, enable the UART transmit
// buffer empty interrupt
void PCSerial::Putc(char c) {
outbuf[wp] = c;
disableTxIrq(); // ---- critical
wp = ++wp & pointer_mask;
enableTxIrq(); // ---- \critical
if (wp == rp) {
overflow = true;
} else {
overflow = false;
// This is the UART transmit buffer empty interrupt service routine
void PCSerial::TxISR(void) {
// If the output FIFO has data, copy the head to the UART
if (rp != wp) {
pc.putc(outbuf[rp]);
rp = ++rp & pointer_mask;
// If the output FIFO is empty, disable the transmit buffer empty
// interrupt
if (rp == wp) {
disableTxIrq();
void PCSerial::enableTxIrq(void) {
LPC_UART0->IER |= 0x0002;
void PCSerial::disableTxIrq(void) {
LPC_UART0->IER &= ~0x0002;
In case you're curious, I'm using the mbed to acquire data from an ADIS16355 IMU over the SPI bus and send it to a host PC over the serial port.
yahugh!
Hi Y'all,
#include "pc-serial.h" DigitalOut alive_led(LED1); int main() { PCSerial pc_serial; char c = '!'; while (1) { alive_led = 1; wait(0.2); pc_serial.Putc(c); alive_led = 0; wait(0.2); c = (c + 1) & 0x7f; if (c<=0) c = '!'; } }#include "mbed.h" #include "LPC17xx.h" class PCSerial { private: static const int outbuf_size = 32; static const int pointer_mask = 0x1f; char outbuf[outbuf_size]; volatile int wp, rp; bool overflow; void TxISR(void); void enableTxIrq(void); void disableTxIrq(void); public: PCSerial(void); void Putc(char c); bool isOverflow() {return overflow;}; };#include "pc-serial.h" Serial pc(USBTX, USBRX); PCSerial::PCSerial(void) { // init the serial port pc.baud(115200); pc.format(8, Serial::None, 1); // init the output FIFO wp = 0; rp = 0; // Attach a member function to call whenever a transmit buffer empty // interrupt is generated pc.attach(this, &PCSerial::TxISR, Serial::TxIrq); disableTxIrq(); // initially disabled since the output FIFO is empty } // Copy the input byte to the output buffer, enable the UART transmit // buffer empty interrupt void PCSerial::Putc(char c) { outbuf[wp] = c; disableTxIrq(); // ---- critical wp = ++wp & pointer_mask; enableTxIrq(); // ---- \critical if (wp == rp) { overflow = true; } else { overflow = false; } } // This is the UART transmit buffer empty interrupt service routine void PCSerial::TxISR(void) { // If the output FIFO has data, copy the head to the UART if (rp != wp) { pc.putc(outbuf[rp]); rp = ++rp & pointer_mask; } // If the output FIFO is empty, disable the transmit buffer empty // interrupt if (rp == wp) { disableTxIrq(); } } void PCSerial::enableTxIrq(void) { LPC_UART0->IER |= 0x0002; } void PCSerial::disableTxIrq(void) { LPC_UART0->IER &= ~0x0002; }In case you're curious, I'm using the mbed to acquire data from an ADIS16355 IMU over the SPI bus and send it to a host PC over the serial port.
yahugh!
