Hi. I have stumbed upon something which is really confusing to me. (unless it's really basic)
I tried to implement a basic state machine. So there are three task and two of them have a single loop. I observe that when I use a loop the event occurs only once but once I unroll the loop it behaves ok. I tried to use a global variable with no effect.
InitializeSystem();
state_table[curr_state]();
void Task1(){
for(int j=0;j<4;j++){ //blink only once
led1 = 1;
wait(1);
led1 = 0;
curr_state = BlinkTwoLed;//next state
I'd predict not only does it only flash once instead of four times, it *also* flashes for 4 seconds rather than 1 second (which should give a clue).
I think your problem is just a slip in your led flash code. In:
for(int j=0;j<4;j++) { //blink only once
led1 = 1;
wait(1);
led1 = 0;
you only have a delay after turning the led on. So on all but the last iteration of the loop, it'll turn off the led and then immediately turn it on again as it re-enters the loop; so you wont see it. So change it to:
Hi Dimiter,
<<code>>
led1 = 1;
wait(1);
led1 = 0;
<</code>>
<<code>>
led1 = 1;
wait(1);
led1 = 0;
wait(1);
<</code>>
and all should be fine!
Cookie Policy
Access Warning
int main() { InitializeSystem(); while(1) { state_table[curr_state](); } } void Task1(){ for(int j=0;j<4;j++){ //blink only once led1 = 1; wait(1); led1 = 0; } curr_state = BlinkTwoLed;//next state }Any ideas appreciated.
