Hi Shareef,
do I need to do anything special (or straightforward) to get my Mac to recognise mbed as a serial port? Your doco tells me to look at /dev/tty.usbmodem* but I don't have anything that matches.
That depends. Have you been using it on windows?
If so, it is likely you put an "mbed.ini" file on the disk to enable the windows-specific serial port mode. Assuming you did, just delete this and then power-cycle (unplug + replug the mbed), and it'll come back up in the default mode, where the serial port should work for mac/linux.
If that is not the case (i.e. there is no mbed.ini on your disk), we'll need to investigate more, but i suspect that is the case. Please confirm either way...
Shareef.
