Hi Clemens,
For my touchpad project I need to alternate the function of some pins between an analog input and a digital output. To do this I probably have to access the registers directly as I don't see how to do this using AnalogIn & DigitalOut (dynamic pin allocation?).
The natural way in C++ is to dynamically create objects, either as local variables or using new/delete.
As an example using local variables (i.e. allocated on the stack), see:
http://mbed.org/users/simon/published/aadb7ad83d46450b9ea13e1c1282456d/AnalogInDigitalOut.zip
which basically does:
float do_something_analog() {
AnalogIn x(p20);
return x.read();
void do_something_digital() {
DigitalOut x(p20);
x = 1;
wait(0.5);
x = 0;
The constructor of objects (when you define e.g. AnalogIn) sets things up. The alternative would be to allocate on the heap using new/delete and pointers to the objects.
Not sure if this is ideal, but it should be enough to get you going. We can learn from there...
For my touchpad project I need to alternate the function of some pins between an analog input and a digital output. To do this I probably have to access the registers directly as I don't see how to do this using AnalogIn & DigitalOut (dynamic pin allocation?). The register names from the datasheet are not recognised by the compiler. Is there an "mbed way" to do this? Or am I supposed to provide my own definitions? Or is there an other way to achieve this? I don't want to use more pins.
Clemens
